big 16g or 20g ? that is the question
as the title says - thinking of getting a 1g which would be better ? will the 20g spool up quick enough - i've heard the big 16g spools up @ around 3500rpm ? let me know what you think thanks any input is appreciated
all depends on what you want out of the car. personally i say go with the evo3 16g. $569 shipped to your house. Basically the best bang for your buck right now. One key piece of advice.... dont think by only settling for a 16g that your car wont be as fast as if you were to put a 20g on it. All depends on your current mods. Have Fun
Eric
AIM: Ep41382
Eric
AIM: Ep41382
Talk to DSTGST and he can get you a deal on one!
MODS: EVO III 16G turbo, EVO III mani, EVO III O2 housing, GReddy 24R FMIC with all piping, HKS BOV w/recirc kit, GReddy Profec B spec 2 boost controller, HKS turbo timer, Cheapy intake, APEXi N1 turbo back exhaust, B&M short shifter, Prothane motor mounts, blitz boost, oil pres. guages and autometer a/f guage.....Soon to go in JDM 6 bolt motor, 550cc injectors, 255 high pres. fuel pump, APEXi SAFC2, all sitting here waiting on some more parts to come in for the swap.
The cost involved with a 20g is not limited to the cost of the turbo alone. The whole setup is different. your intercooler pipes are no longer stock style. Coolant and oil lines need to be modified or changed. You probably want to go with an external wastegate setup on a 20g. Not to mention 20gs move more air. you probably need to reconsider your mas air situation. you'll need bigger injectors... should I go on?
evo big 16g. great for the money, quick spool and the compressor wheel is just almost as big as a 20g compressor wheel. thnaks mike
TURBO IS THE ONLY WAY TO GO. IF YOU DON'T HAVE ONE GET ONE. HA HA
ALSO FRIENDS DON'T LET FRIENDS DRIVE STOCK.
When I see someone run 10s on an EVOIII 16g in a DSM, you can call me a believer.
It's a great turbo, but dont compare it to a 20g. It's not even in the same class. Really.
