How can the most simple shit make you feel like such a moron
If you dont want to read a rant, hit the back button now.
Go to change rear pads and rotors today. Get everything jacked up, caliper off and gently persuade the rotor off with a hammer. Spend the next hour trying to get a C-clamp on the piston to press it out of the way, only to read on dsmtalk that the rear piston, unlike the front has to twist in. (Big fuckin thanks to mitsu for that one). Spend the next 30 minutes with a needlenose bustin knuckles to finally get the piston out of the way. Put the new pads in and go to put the caliper in place. Wouldnt you know it, but now the parking brake cable doesnt have enough slack to allow the pads to slip over the rotor. Greeeeeat. Look at the cable and realize i have no clue how to disconnect it. Consult what must be the text-only version of the Chiltons manual and read the detailed step-by-step instructions. "Disconnect parking brake cable from caliper" No fucking shit! Not a picture or diagram in sight. By this time its almost completely dark, im getting torn up by mosquitos, and bleeding from 3 different locations. So here i sit: tired, sore and with my daily driver on jackstands. Maybe i should just install some squirter lights and be done with it, although id probably find a way to make that harder than it is also.
/rant
/rant
"So...is there any tread left on the tire..or at this point would it be like throwing a hotdog down a hallway"
-Stewie (Family Guy)
thats how it is with dsm's, the things you always think are gonna be simple, end up being a pain in the ass, the things you think are gonna be hard are easy. Ahhh dsm's, pain in the ass, but well worth it when your driving them!!
"Maybe one day I will be rich enough to have a secret lair with an army of ninja's at my disposal!!"
Ill be in the same boat as you in the next couple of weeks. Hopefully with out all the problems your having.. Good Luck
AIM: Boost113
New best time @ Jennings 1:25.4
AIM: Boost113
Jeeze that sucks, Im sure youll overcome whatever problems you have and you will love your car when your done. Sit back, take a deep breath, and relax.
Gripped XS | 18-55 IS | 50mm f/1.8 MK II | Sunpak 5000af
another stupid thing about dsm's i have had a few other people i know had was there cheap but expensive to replace driver side door handles break. anyone else had this problem
AIM: MitsuEclipseRS99
Holla
Holla
Can someone translate that for me.
Tom
Tom
almost dumped 07 SI
almost dumped 07 SI
