vibrations under boost ?
Old Oct 23, 2003 | 05:19 AM
slowy's Avatar
13.04@104mph
Default vibrations under boost ? **************
was datalogging and tuning last night
and when i would get into it the car would shake, kinda like the tires were out of balance, but when i went the same speed cruising, there was no vibration.
friend of mine mentioned driveshaft?
i have no clue
any help would be greatly appreciated
Thanks
Old Oct 23, 2003 | 05:52 AM
Ep41382's Avatar
TR Balla Donor Supreme
ya i remember feeling that in your car when we were testing out that quality new IC pipe you constructed drive shaft is a good idea, what about motor mounts, maybe you have a cracked one or something
Eric
AIM: Ep41382
Old Oct 23, 2003 | 06:14 AM
Ep41382's Avatar
i just got to thinking, forget the motormount idea, it only vibrates under boost.......hmmmmmmm
Eric
AIM: Ep41382
Old Oct 23, 2003 | 08:53 AM
psifactor's Avatar
Hello
I had a similar problem awhile ago. took me forever to figure out what it was.
My vibration was so bad it was almost impossibile to drive the car. changed the driver side half-shaft and that took care of the problem. Its rare for an axel to get so bad, but it does happen. Maybe check to see if yours both are ok.
does it vibrate at all when just normal driving not under boost?
Heavy car with a 2.5L
Old Oct 23, 2003 | 09:13 AM
slowy's Avatar
13.04@104mph
no vibrations till it gets under load, normal driving at every rpm/speed is fine
Old Oct 23, 2003 | 02:27 PM
Nick's Avatar
Ridin dirty
Check your axles
AIM: Boost113
New best time @ Jennings 1:25.4
Old Oct 23, 2003 | 07:44 PM
slowy's Avatar
13.04@104mph
check what about them?
Old Oct 24, 2003 | 01:16 PM
flubyux2's Avatar
Elitist Supra Asshole :)
make sure they dont move... if they do, duct tape them. grab the axle and try to move it... it sholdnt move at all... ours move alot and the boot was separated and the whole CV joint was showing... slung grease everywhere, it was gross
Old Oct 24, 2003 | 03:35 PM
Nick's Avatar
Ridin dirty
Well did you check . I would like to know what you found out. Thanx
AIM: Boost113
Old Oct 25, 2003 | 05:53 AM
slowy's Avatar
13.04@104mph
just read the thread again this mornin, ill check today
should i try to wiggle the driveshaft also, just for kicks?
