booooooost
Old Aug 17, 2003 | 01:22 PM
ReDsM's Avatar
"Owell"
Default booooooost
stock boost actuator at 14psi... no way... any way to make more boost from stock actuator besides the little screw thing
Old Aug 17, 2003 | 01:54 PM
PoppaSmurf's Avatar
Chowdah-head
ya...its called a "boost controller"
Poppa J. Smurf
Old Aug 17, 2003 | 02:27 PM
Chris LS's Avatar
just blaze...
Quote : I'm Slow:
Less hours = less $$. Less repetitive 'ish every day = PRICELESS!
Old Aug 18, 2003 | 03:39 AM
psifactor's Avatar
Hello
You can get one for like 10 - 50 bucks. that is MBC
I would also suggest not using your stock boost guage...thoes are pretty much worthless. Get an aftermarket auto meter or something so you get accurate readings.
Heavy car with a 2.5L
Old Aug 18, 2003 | 08:04 AM
nouseforaname's Avatar
16.4@84mph
It is possible to run a "T" in the line from you boost signal to the wastegate actuator and leave the "T" open to the atmosphere. We did this on my friends 93 TSi FWD and it gave about 2.5 lbs. per "T". The boost increase depends on the gauge of the hose/"T".
Good luck and I hope you have the fuel to back up the boost.
89 Mirage-Intake/Header/Exhaust
AIM-queerpuncher
Old Aug 19, 2003 | 11:05 AM
JoeZ's Avatar
sounds ghetto. Visit DSMTUNERS website and read some archives. Then go on EBAY and get a "manual boost controller" (mbc)
College Tampa - It's Where The Party's At!
Old Aug 19, 2003 | 04:12 PM
ReDsM's Avatar
"Owell"
when i got my car, a buddy with same car said it seemed faster than his (stock). so when i got a boost gauge it read 14 pounds steady until redline... so i had him look at it. he jus told me i was lucky and then i got a mbc and another boost actuator. i was thenrunning 20+ pounds. mbc is disconnected and im running stock boost everything.now this new boost actuator only gives a steady 10 pounds. where do i find these limited 14psi actuators?????
TRYIN TO RIDE "CLEAN"
Old Aug 19, 2003 | 10:12 PM
Crab Cakes's Avatar
So Lost!
I would get the Greddy profec b if you can afford it..You can ffind them used for like 200..
Im The Original Crab!
Old Aug 20, 2003 | 07:00 AM
HFGreg's Avatar
P.I.M.P
20psi? damn...I'd be afraid to blow something if stock...
