2000 mazda protege engine swap
Old Jan 26, 2010 | 11:30 AM
shark524's Avatar
Default 2000 mazda protege engine swap
i have a 2000 mazda protege with a 1.8L engine and a 5 speed transmission. i want to swap the engine, transmission, and drive axles wih that of a mazda 3 around the 2005 years. what modifications do i need to do. i know that the mazda 3 is wider so is there anywhere that i can buy shorter drives axles. motor mounts difference crossmember difference ect
Old Jan 26, 2010 | 11:49 AM
tito_12a's Avatar
why ?
R.A.P.S member number #0004
Rotaries
Against
Piston
Swaps
Tampa Bay Rotary Owners ClubMember # 5
Originally Posted by Empire
a girl just got identified by an ass pic...
that seriously just happened...
Tr is great.
Old Jan 26, 2010 | 12:24 PM
shark524's Avatar
power and ease of getting performance parts. alo it should be fun to swap
Old Jan 26, 2010 | 02:12 PM
Slo_RydP5's Avatar
Ryce Hater
not going to happen.....unless you got $$$$$$$$$$
2 totally different drivetrains...engines....ecu's...everything
you're better off swapping in a KL-ZE or the other MX-6 motor if you want more power
Old Jan 26, 2010 | 03:45 PM
shark524's Avatar
so if i swap my engine with one from an mx-6 i don't have to change any of the drivechain?
Old Jan 27, 2010 | 02:22 PM
Slo_RydP5's Avatar
Ryce Hater
drivetrain...you mean.....
both of these threads should help you out....
the 1st link is for a swap into a 2000 Protege like you have....the 2nd link is a swap into a 02 Protege 5, but it's basically the same as what you have
Slotege KLZE Swap Thread - Mazda Forums
KLZE how to - Mazda Forums
Old Jan 27, 2010 | 04:27 PM
shark524's Avatar
thanks a bunch those links were extremely helpful
Old Jan 27, 2010 | 05:20 PM
Slo_RydP5's Avatar
Ryce Hater
no problem. that site has LOADS of helpful info and a lot more Mazda enthusiast that are willing to help, all the mazda peeps in this section are mainly rotary peeps.
also something else you might want to look into.....if ur engine is still in good shape (meaning you haven't blown a hole in it.....look into forging the engine and turboing it....
i'm not sure if the 00 protege's 1.8L are the same as the miata 1.8L, but if they are i know they will hold boost from turbo's real good.
or a BP-T swap.....
Old Jan 28, 2010 | 04:53 PM
sil80redtop's Avatar
Why don't you just buy a 05 Mazda3 and save yourself a whole lot of trouble? Better yet, buy an 07 MS3.
AB
