ecu tunning options ?
well i have a 90 fc3s gxl n/a and its had some stuff done to it as far as i can see some one blocked off some stuff on my 13b who ever had it last blocked some something and also im not seeing any o2 sensor its running fine when it gets warmed up but when driving its evry time i go to stop at a red light it struggles to idle back up by it self and i have to keep a little bit of foot on the gas on a cold start its also seems to be running rich but what i really want is for someone to answer this qestion is their any ecu upgrades tuneable system thats plug n play that way i can get this bitch to run good plus more power if i can have the abilty to tune it with a laptop ??? list what would be idel for me to have... greedy emange ? aem ? haltech ? let me know i want to also have the abilty to have a revlimter
You have a revlimiter... Should be between 7 and 8.5k ish. It might not buzz anymore, but it should still be there! An o2 bung really isnt that diff to get going, and if your doing a plug an play, id throw a wideband in it, so you can see whats going on as your riding around. Any of the upgrades you listed will work just fine, just go with which ever one is easier for you to use/understand.
Tampa Bay Rotary Owners Club Member # 4
PIT KREW
TEAM MEMBER
________________
Team Decep!
you never saw it coming
PIT KREW
TEAM MEMBER
________________
Team Decep!
If you don't have the budget for a haltech or microtech, build yourself a megasquirt system. You can pick up a used stand alone for around 700$ just have to find someone parting their car out.
And you CAN tune that chip, you just have to buy the next stage up which costs $400. That can be tuned with a hand held or a laptop.
i knew the person that used to make plug n play megasquirts for fcs. i used to have one in my old t2, now i run a haltech e6k.
u should look into the rtek 2.0, its great tunable with a pda and comes with base map that runs ur car like factory pretty much.
last person maybe have blocked off the BAC valve, whats ur idle at normally?
today i installed a shift lite and got my rear strut bar in maby im gonna ride out to causeway or McDonalds to show all the ricers what a real jdm rotary car is lol
normal rotary idle sounds like it mises anyway.
brrrrrrrrrrrrrrrrrrrrr................brbrbr...... ..brrrrrrrrrrrrrrrrrrrrrrrrrrrr.........brrrrrrrrr rrrrrrrrrrr......brbr.......brrrrrrrrrrrrrrrrrr
if that makes any sense lol
lol u may have a vac leak, that idle is really high! 1k isnt bad but 1,500 is too high.
just need to get a porting template and the right tools lol
