94 protege clutch wont disengage.
Old Aug 16, 2009 | 09:09 AM
Trky's Avatar
Android Junkie
Default 94 protege clutch wont disengage.
Friends car wont drive because the clutch wont disengage. I don't know dick about this car so I thought I would come here for advice. I'm going to go look at it in a bit but I'm not really sure what I'm looking for. He said he drove it fine and then let it set for a couple months now it won't disengage.
Old Aug 16, 2009 | 07:27 PM
96rdstr's Avatar
TR Noob
slave cylinder or the clutch rod needs to be adjusted.
96 Miata, Garrett T3, Megasquirt, AEM WBO2, HKS SSQVBOV, FMIC, RX7 460's, Turbonetics Ex WG, running 12.7psi.
Old Aug 17, 2009 | 02:51 PM
Trky's Avatar
Android Junkie
When you depress the clutch it feels normal but the clutch isn't disengaging. You can put it in gear when the car is off but not while running. My cousin seems to think it might be the clutch itself. I'd rather not replace it if not absolutely needed, is there a way I can test the slave? How do you adjust the clutch rod?
Old Aug 27, 2009 | 12:45 PM
markstheman365's Avatar
cant slide
check clutch fluid...idk if clutch and brake resevoir are the same on those cars but deff. check fluids
contact admin@tamparacing.com to advertise on here.. - mod
