brake?
Old Jul 3, 2009 | 05:22 PM
dragon13's Avatar
Default brake?
i have a 87 rx7 with single piston brake calipers. Will the 4 piston caliper from the same car fit with no problem? or do i need something else to make it fit?
Old Jul 6, 2009 | 06:18 PM
somestone's Avatar
check bolt distance and make sure it actually covers the disk with pads,
you dont want any steel rubbin in there (500F)
Old Jul 11, 2009 | 08:02 AM
sharingan 19's Avatar
"Da Man"
if you already have 5-lug hubs...yes. If not it would be easiest to just get the 5-lug hubs and brakes and install them at the same time.
"If losing you are yet no mistakes you have made, a different game you should play" - Yoda
Old Jul 13, 2009 | 05:57 AM
Niburu's Avatar
Sic semper tyrannis
check your rear brake rotors and see if they are solid or vented
also since this car is NA there is really no reason to upgrade to a set of 4 piston calipers unless your tracking the car on a road course
I would also check and make sure the master cylinder is the same for both
2011 Subaru Forester - the daily driver kid hauler
1990 Miata - track whore
LOVE THIS TAMPA CAR RACING SCENE
