mx6 clutch/tranny help
Old May 19, 2009 | 12:06 PM
markstheman365's Avatar
cant slide
Default mx6 clutch/tranny help
my clutch seems to be going bad, but thats not all. also it seems as if the clutch isnt fully disengaging. ill be driving then let go of the gas and press the clutch in and it sounds like i dont have the cluthch down (downshift). also if i idle in first with the clutch down it revs up and down and almost stalls out, then after a minute or 2 it just dies on me. also the car battery seems to be drainging when i do this.
plz call me at 813 679 1441 with any help thx
contact admin@tamparacing.com to advertise on here.. - mod
Old Jun 2, 2009 | 06:30 AM
somestone's Avatar
PRESSURE PLATE ISSUE...
YOU NEED TO SWAP NEW CLUTCH HAPPYMEAL (CLUTCH, PLATE, THRUST BEARING ETC)
CHECK FOR A VACUUM LEAK..... (if i idle in first with the clutch down it revs up and down and almost stalls out)
OR YOU MIGHT WANNA START BY CHECKING YOUR HYDRAULICS.. MASTER & SLAVE CYLINDERS (about 30.00 to rebuild) - its the cheapest answer....
OTHER THAN THAT YOU NEED TO TAKE TRANNY DOWN AND LOOK AROUND....
AND LAST BUT NOT LEAST - I WOULD GET THAT BATTERY CHECKED..... MOST ADVANCE AUTO PARTS WILL DO IT FOR FREE......
