help!!
Old May 5, 2009 | 03:12 PM
moshman1205's Avatar
Default help!!
i have a '96 ford probe but i'm posting in here cuz my understanding is that its all mazda under the hood anyway... its a 2.0 and i thought i needed a fuel pump but i put a new one in and its not doing anything, acting like its not getting power to it at all. the relays click under the hood but the pump doesnt wine, not even when its turning over. ANY IDEAS THOUGHTS at all?? Thanks Devin.
Old May 5, 2009 | 06:12 PM
MazdaMX3Freak's Avatar
Vtack THIS!!!
What is your fuel pressure? did you check spark or your igniter?
-2008.5 Mazdaspeed3 CWP
Old May 5, 2009 | 06:37 PM
i put the tank back up and i hear the fuel pump whine but it doesnt start.. yes there is gas in it... any input?? it does start with starter fluid..
Old May 6, 2009 | 09:08 AM
all better... so performance parts?? i have strut tower bars comin in a week...
Old May 7, 2009 | 02:56 PM
CoRDiTe's Avatar
Not Mad
Hmmmm......... Lets start from the beginning even though you said it starts with starter fluid. Process of elimination.
1. Do you have spark ?
2. Have you replaced the water pump recently ?
3. Is your timing belt still in one peace ?
4. Have you changed your plugs, or wires recently?
5. Have you checked your Fuel pump fuse ?
6. Have you checked your main 80 or 100 fuse ?
7. Have you recently messed with your M.A.S?
8. Have you touched any of your hoses ?
9. Have you checked your fuel pump physically?
10. Did you drop the fuel tank and physically touch the fuel pump?
11. Did you remove/disconnect any of the fuel pump hoses?
12. Have you checked your distributor rotor ?
Old May 7, 2009 | 07:28 PM
yes i checked most of that, but it was the fuel pump shut-off switch... or what should be... i fixed it and its drivin good now, thanks man
