anyone works at mazda?
Old Feb 13, 2009 | 06:29 PM
alri0085's Avatar
Scuderia ALRI
Default anyone works at mazda?
my rx8's ignition was replaced and it has a new key. the problem is that the key itself needs to have a code that matches the car. the DIY way requires 2 working keys, which i have none. so i need to take it to the dealer, but how can i do that if it doesn't start? anyone willing to help?
also, i just put spark plugs in the car, but the wires don't have any marks to show where they go. i connected the 2 colored wires to the T spark plugs. i read that somewhere but it didn't say if they were interchangeable. does anyone know this?
Old Feb 14, 2009 | 09:25 AM
alri0085's Avatar
Scuderia ALRI
TR's Mazda tech FTL. shit's weak son!!
Old Feb 15, 2009 | 05:54 AM
TheCamel's Avatar
Damn I take a day off, and come back to this...
Ok as far as the key issue, yes it is going to need a dealer as the system has to be coded to the chip in the key. Not having one to match it, will require the tech to go into the OBD II port, and force the computer into a learn mode, each key will be inserted and assigned a code. As far as getting it there, you are either going to have to find a friend with a trailer/dolly or call a towing service.
As far as your spark plug/wire issues I will do my best to explain.
You have 4 spark plugs, 2 leading and 2 trailing. The leading plugs are located at the bottom of the motor, and the trailing are on the top. On your coils it will be marked L1 T1 L2 and T2
L1 = lower spark plug hole closest to the front of the motor
L2 = lower spark plug hole closest to the rear of the motor
T1 = upper spark plug hole closest to the front of the motor
T2 = upper spark plug hole closest to the rear of the motor
So look at the coils, and route your wires to the appropriate plugs using the information above.
Rotaries are 20% motor, and 80% tuning
Old Feb 15, 2009 | 08:19 AM
alri0085's Avatar
Scuderia ALRI
thanks dude. i'll try that and let you know how that goes.
Old Feb 19, 2009 | 07:27 AM
somestone's Avatar
Sicke!!
Well ??
Nice Write Up Camel
