Mazda MX-6 info needed
Old Jan 19, 2009 | 03:50 PM
Theperkman24's Avatar
Default Mazda MX-6 info needed
I have a 93' MX-6 and was wanting some opinions on what i should do about boosting and a motor swap, maybe ordering a new stock engine for mx-6....? any info will helo
Old Jan 21, 2009 | 02:53 PM
treekiller's Avatar
legend behind the cowl
you have the 2.0 4 banger or the 6 cylinder. the 2.0
If you have the FSDE 2.0 you can boost it pretty cheaply, the 6 cylinder is a bit harder to boost and a lot more expensive. there is also the factory FSZE which is the high performance 4 cylinder from japan, but a little harder to swap. the 200hp KLZE is the popular swap over our standard 164hp KLDE 6 cyl..
hopefully you have the 4 cylinder since it's low compression and boostable.
Old Jan 21, 2009 | 04:18 PM
jpatanio's Avatar
you can boost all day long on the v6... you just have to have the right tune on it. Even if you did pop the motor its a quick trip to the junk yard and a couple of hours to throw in.
You should be able to pick up a decent set of pipes on ebay... the knock offs are just about as good as the ones made by the other companies.
rotary4life
Old Jan 21, 2009 | 06:30 PM
treekiller's Avatar
there you go, I did not see a turbokit for the V6, but typically 2 manafolds ect tend to add cost.
Old Jan 21, 2009 | 07:04 PM
yeah, definitely feel you on that. thanks. just take a lil money and sweat to work with
Old Jan 21, 2009 | 07:11 PM
MazdaMX3Freak's Avatar
Vtack THIS!!!
thats b/c the 3.0 v6 can in the 88-92 box models. and have hardly any hope for modds. the 93-97 models came with the 2.5l v6 and this is the one you are looking for. It can handle over 300hp to the wheels in stock form. The blocks and cranks have been tested to over 800+ to the wheels! just a lil KL info. for the day
-2008.5 Mazdaspeed3 CWP
Old Jan 21, 2009 | 07:13 PM
yeah it is a V6, thats why wondering bc the current motor isnt doing too hott, so i was thinking getting a new one or a swap to begin with
Old Jan 21, 2009 | 07:16 PM
yeah, it is a 2.5l v6, what you thnk i should start first on it>?
Vtack THIS!!!
-ill tell u what if u buy a new motor. ill swap it in for you. In return for your old motor
Old Jan 21, 2009 | 07:18 PM
Vtack THIS!!!
well PM me your goals for your and spending limit and ill tell you everything u need to know.
