miata motor upgrade
check out racingconsepts.com
not cheap but better then stock fuel economy, very reliable, and 11.7s at 120 with a stock motor, 11.2s at 132 on a 100 shot.
or the 1.8 it can hold 400+ on turbo stock internals, actually theres one with a 30r running 125mph in the quarter on a completely stock motor.
check out racingconcepts.com
not cheap but better then stock fuel economy, very reliable, and 11.7s at 120 with a stock motor, 11.2s at 132 on a 100 shot.or the 1.8 it can hold 400+ on turbo stock internals, actually theres one with a 30r running 125mph in the quarter on a completely stock motor.
O.P. If you want to build a cheap and reliable 1.8l motor then here are some suggestions.
-1994 block
-1999 head
-wiseco pistons
-crower rods
-metal head gasket
-miata link ecu pretuned OR megasquirt ecu
-550cc injectors OR higher
-walboro 225 fuel pump
-basic bolt on turbo kit
that list you are looking at 3k easy, for a reliable build. if you want loads of power, you will need a bigger turbo and a good tune. the 1.8l is a good turbo application, but NO the stock motor will not handle more then 7lbs reliably.
yea 400hp out of a 1.8 stock internals my fucking ass.
The easiest 1.8 to swap is the 94-97 1.8L. Although the 99-00 1.8l has a better Flowing head you cant adjust the timing.
A stock 1.8 can take like 12-14psi and make 250-275Whp. build the motor and they can make 600+.
you can turbo a 1.8 for 1500-6000 depending on the parts and end power goals.
Damn Captin came in while i was writing that. I agree with him 100% except for the 7psi BS.. i know plenty of 12-15psi Completly stock internal 1.8s with 10-50k of turbo miles on them.
I forget which year they bumped the compression but i think it was 99+ so avoid high boost on those.
block and head are the best choice.
Wiseco and the best pistions.. i like the 1s from FM.
Crower rods are alittle pricey.. I like Mtuned rods for a budget build $349 and good for 600hp
I perfer Megasquirt
Other then that hes dead on.
I perfer Megasquirt
yeah i have seen quite a few 12-15psi turbo application stock internals miatas, but MOST of them had upgraded fuel injectors and a few things here and there. I boosted my 2002 special edition way back when and ran it at 10psi and the clutch lasted about a month. i believe fully in building every reliability mod "required" with every power mod you add on. to each there own i suppose, but you are right and more experienced then i am.
and i am not sure, but i think the compression bump was either 99 or 2000. just remember that all the extra power is meaningless without a way to get the power to the ground. suspension, bracing,clutch,flywheel, and tires take the car to another level.
Oh of course i agree 100%.. Stock injectors your limited to like 7-8psi on the 1.8 and like 6psi on the 1.6.
And a clutch is needed even at 6psi.. Shit my stock clutch cant take a 65shot on a bottle with only 650psi..
Im not sure im more experienced then you but i was saying that stuff under the impression that he knows what hes doing.
If he can do the 1.8 swap he should know enough to put a better clutch and Bigger injectors on it.
