2000 Protoge obd code help
Old Nov 6, 2008 | 03:47 AM
RoadRacer's Avatar
Turn 7 at Sebring
Default 2000 Protoge obd code help
A friend of mine is having some trouble with his 2000
Protoge. The car is a base model sedan, automatic with 108,000 miles
The symptoms are the car shifts hard and generally won't go into overdrive.
The car is throwing a CEL so we checked the numbers.
P0771 - Shift Solenoid E Performance
P0741 - Torque Converter Clutch Circuit Performance or Stuck Off
Does anyone have experience with these codes?
Is the torque converter going bad, or is there a solenoid that goes bad?
If it's the solenoid, can it be replaced independent of the tranny?
Thanks for the help.
Patrick -
Old Nov 8, 2008 | 05:28 AM
RoadRacer's Avatar
Turn 7 at Sebring
Does anyone have any info on this?
Patrick -
Old Nov 8, 2008 | 05:42 AM
93LowBody's Avatar
TR Balla Donor Supreme
Not mazda speific.. but usualy you Can just change the soleniods.
I would check for bad grounds becuase thats 2 soleniods throwing the light and both of them at the same time doesnt happen much.
Other then that i dont have a clue.
Old Nov 9, 2008 | 06:02 AM
RoadRacer's Avatar
Turn 7 at Sebring
Thanks for the info!
Patrick -
