Wastegate ? For Holset Turbo....
Old Jun 25, 2008 | 08:07 PM
bnr-240sx's Avatar
Default Wastegate ? For Holset Turbo....
What would be the Best Wastegate set up to run with a HX-35 Holset turbo for mid range boost on a 13b?
And what do i do about closing the valve from the internal wastegate? do i weld it closed or what?
Thanks.
Old Jun 26, 2008 | 10:51 AM
RX007CYM's Avatar
Lucky
For the waste gate I think a Standard HKS Waste Gate will take care of business for you. HKS GT Wastegate As always, stay away from the ebay knockoffs.
I would remove the internal waste gate and use a block off plate. Some people do as you have already suggested and just simply weld it shut.
What is the hot side a/r of this turbo?
~James
Originally Posted by JustMiata
It's like this: The toadstool juice fires through the unicorn injector into the fairy dust chamber, where the tiny wizard does his secret work...Then a gang of keebler elves get hopped up on the crystalline byproduct of the wizard's tinkering, (they smoke it) and then the elves push the spinning triangle through a series of dimensional portals to a final realm codenamed the "exhaust port..." At least that's my undersanding of rotary sorcery...
Old Jun 26, 2008 | 07:03 PM
bnr-240sx's Avatar
Im pretty sure it's .70 but not sure. dont kno where to look that up at.
Old Jun 26, 2008 | 07:05 PM
YARO's Avatar
Smith & Wesson Protected.
Tial or turbosmart are the best choices
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Jun 26, 2008 | 08:42 PM
bnr-240sx's Avatar
I've been checking out the Tial 38mm.
Old Jun 26, 2008 | 08:59 PM
power2weight's Avatar
-eats the last cookie.
There should be a large number cast into the turbine housing, 12, 14, 18, 21 etc, denotes the size of the housing, I haven't seen a map of an HX35 yet, but I've been told the 21 cm housing is comperable to a 1.08 AR. Works for me, I just block off half the scroll with a 1/8" plate and let it spool faaaaaaaast!
I run a turbonetics evolution on my HX35, 2.3L and has no boost creep at a relatively low 14lbs (ie you need a bigger gate the lower boost levels you run because the gate will be venting more gas).
You can wire the internal gate shut with stainless wire. A friend of mine ran 40lbs with the flapper shut that way. Although if your never going to use it again you could weld it.
I would look for a non-internal gated housing myself. V-bands>bolt on housings IMO.
"They must really feed each other to the lions down there........"
Old Jun 27, 2008 | 07:52 AM
bnr-240sx's Avatar
Heres a link to the pics of the turbo. www.floridadrift.com :: View topic - F/S HOLSET TURBO $400 O.b.o.=
Old Jun 27, 2008 | 08:54 PM
bnr-240sx's Avatar
The air ratios for the Holset HX35 varies from 1.33 to 2.34. So somewhere in there. lol if that helps any.
Old Jun 27, 2008 | 09:07 PM
A/R is an abbreviation for area/radius, and no offense, but I doubt those numbers highly.
And that looks more like an HE341, I'm almost 100% sure its not an hx-35 (mine):
Old Jun 27, 2008 | 10:07 PM
bnr-240sx's Avatar
U kno what i think your right on the turbo. lol wow i suck at looking shit up. well they look similar i guess.
Well thank you very much for finding that for me.
