10% or less ethanol
Old May 19, 2008 | 06:02 PM
tito_12a's Avatar
Default 10% or less ethanol
will having 10% or less ethanol in gas hurt rotaries, specifically the 12a ?
Old May 20, 2008 | 09:59 PM
fd3ETTY's Avatar
no dude its just there to clean up emissions google that shit or something or ask a mechanic it burns alot nicer than gas as well
Old May 20, 2008 | 10:00 PM
fd3ETTY's Avatar
oh and its cool as hell to play with in chem labs
Old May 21, 2008 | 07:04 AM
norachelhere's Avatar
fails.....
will straight ethanol hurt the motor? No. It has some advantageous and what not. It burns "better" It takes a higher compression, etc etc etc.
Will the mix shit hurt your motor? Not really. It isn't going to kill the motor, but your gas mileage will drop at least 30 and up to 60 miles per tank. The ethanol needs a different "environment" to do its thing. It wants more advanced timing, and higher compression. It also have a lower level of stored energy. That stuff isn't a problem when it is just ethanol. The problem is, with it mixed with normal gas, you can't advance the timing, you can't up the compression, you can't do anything because of the limits of gas. That means that the ethanol part of the mix doesn't get enough heat and compression to burn until after the main explosion. Which, is right about when the exhaust valve, or port in this case, is opening. That only allows a fraction of the ethanol to actually burn properly. All that added ethanol does to the fuel mix is limit the power of the main explosion. Which leads to a crappy power band, crappy response, and horrible gas mileage.
the short answer, no, it won't kill your motor.
Old May 21, 2008 | 10:03 AM
EnsenCorp's Avatar
Vote for me
I get horribly horrid gas mileage on ethanol.
Originally Posted by biggoofy
if guns kill people , spoons made rosy o donald fat
Originally Posted by Ayn Rand
"Just as I support my life, neither by robbery nor alms, but by my own effort, so I do not seek to derive my happiness from the injury or the favor of others, but earn it by my own achievement."
Old May 21, 2008 | 10:11 AM
fails.....
horibly horrible... that tickled me like something funny...
God, I've having a weird day...
Old May 22, 2008 | 07:36 PM
Jetflat&tripleBlack's Avatar
Not your avg. niccra
Who cares?Make that bitch sing!
Old May 25, 2008 | 04:46 AM
landon303's Avatar
i don't run it in my 12A...
engine, not motor
Old May 25, 2008 | 07:46 AM
tito_12a's Avatar
^ then where do you go ?
Old May 25, 2008 | 08:52 AM
nofxareforkids's Avatar
Wants a RWD again
mazda has issued a tsb for all rotary powered cars they do not reccommend anything more than 10% ethanol.
you don't need to see my identification.
