7 Down.
Old Apr 29, 2008 | 11:32 AM
FDfranklin's Avatar
Single Turbod!!
Default 7 Down.
Car problem - Video
Car videos on my YouTube Channel (Subscribe please!):
http://www.youtube.com/user/FDfranklin
Old Apr 29, 2008 | 04:43 PM
kbprice's Avatar
Rocket Scientist
Best case you have a hose that popped off or IC pipe loose. Worst case, apex seals gone.
'96 Supra NA-T
"I'm not driving fast, I'm flying low..."
Old Apr 29, 2008 | 04:59 PM
FDfranklin's Avatar
Single Turbod!!
It actually has something to do with my power source... I didnt explain anything just posted the video.. I was pretty EMO at the time.
Old Apr 29, 2008 | 05:25 PM
Captain Fap'n's Avatar
Fap Fap Fap
ooohhhh nooeeezzzzzz
sorry man, i hope it's something simple. hates to get something good going and then have it start to act up. best of luck
Old Apr 29, 2008 | 05:35 PM
aaron1017's Avatar
is not Rotarded anymore!
I told Eric to remove his alternator and get it tested. My FD does the same thing when the voltage is low (glowing oil pressure and coolant)
Eric: you better fuckin do it!
LS1/T56 Heads Cam 1994 FD
Old Apr 29, 2008 | 07:08 PM
seventhgear's Avatar
hanglike sleeve of wizard
sounds like an alt on the brink....... go get it tested
image removed from your sig...see forum rules
Old May 1, 2008 | 06:23 PM
rexaholic7's Avatar
I BURN OIL N I LIKE IT!!!
it sounds like some kind of electrical problem with the alternator. get it tested or check the grounds b/c its draining your battery
edit: turn the car on. turn on ALL the accesories, light etc...., if the voltage goes anywhere lower than 12 or it shuts off then the alternator is poop.
Originally Posted by jonBODON
that guy has more skill in his left pinky toe then your whole body...
Very Proud Member of R.A.P.S.
R.A.P.S member number #0003
Rotaries
Against
Piston
Swaps
Old May 1, 2008 | 10:40 PM
FDfranklin's Avatar
Single Turbod!!
Got it fixed yesterday. Took alot of dremel work and alot of runs to AAP lol...
Old May 2, 2008 | 02:17 AM
Rotary Buddha's Avatar
zero pistons
So what was it? Your idel seems really low. Your don't have an airpump right? It should be around 1k-1.5k.
Originally Posted by rotarykidd
you have no idea how many TR members id kill to have this car for just a day...
Old May 2, 2008 | 06:20 AM
FDfranklin's Avatar
Single Turbod!!
Battery was killing the alt because it was only a 100 output battery. I had to replace the the alt and the battery. Im hoping the low power was causing the low idle issue I still need to do some tinkering to my battery holder and then im going to fire it up today.
