Need help.....
Need help.....
recently i bought a 1984 Mazda RX-7 GSL-SE and its hard to start..
i checked the spark plugs and they come out wet.
this is what i did:
*replaced spark plug wires
*spark plugs
*fuel injectors
*hoses
*intake gaskets...
also i checked the tps, etc.,
still hard to start and spark plugs are still getting wet. (T1, T2)
i replaced the stock ignition coils with new msd 2 ignition coils..
i can started once and drvie it..
but after sittin for a few hrs. i cant get it to start...
plz any advice will be greatly appriciated.
elcododao11@msn.com
this is what i did:
*spark plugs
*fuel injectors
*hoses
*intake gaskets...
elcododao11@msn.com
Are your plugs even firing? What are the mods? Make sure timing is on point and the coils are hooked up properly. What plugs are u using?
JDM FC
JDM FC
i did.. all the vac are replaced with new ones..
i can started once.. run it.. let it sit for a few hours and then try to start again and it wont start..
idk know but i think that the pressure regulator has something to do with it..
ok.. so i think i got the problem solved...
i repalaced a few stuff in the car..
*new injectors
*new vacum hoses
*new ignition coils
*new spark plugs and wires
*checked & tested all the sensors
*repalaced the antifreeze
*rebuilt the starter
and now we added a delay switch for the fuel pump..
and it seems to be workin fine so far...
*new injectors
*new vacum hoses
*new ignition coils
