need help with rotary engine
Old Jul 31, 2007 | 09:39 PM
S13 hatch's Avatar
Default need help with rotary engine
my car started when i got it, then when i gave it a tune up and changed the oil i drove it a little bit and it ran funny and i stopped it and tried to start it again and it wouldnt help. If some1 could help me ill even give you some cash to help me out
Old Jul 31, 2007 | 09:40 PM
S13 hatch's Avatar
it started a couple times before then it stopped starting could some1 help plz i got cash if you need some
Old Aug 1, 2007 | 06:33 AM
Rotary7's Avatar
Get Down-Or-Stay Down
Well what do you mean "tune up"
If you changed the plugs,make sure you have the wires right
coils Engine
L1/L2 L1/L2
T1/T2 T1/T2
biggest easiest mistake.
easiest to fix..
follow the wires from coils,it will say either T1/T2/L1/L2
The rotor housing towards the front of the car is 1
The rotor housing to the back of the car is 2
T means trailing,also easiest way to remember is t stands for Top
L means leading,which can easly mean lower..
Match the wires from the coil
L1
would mean rotor housing 1,Leading (lower)
Do you want to be tazed?
Rotary7's Avatar
If you change plugs,stay with NGK!
Other brands can cause internal damage
Old Aug 1, 2007 | 01:56 PM
Captain Fap'n's Avatar
Fap Fap Fap
it may be flooded? try pulling the black and yellow wire underneath your dash closest to your right leg and center console and mash the gas pedal on the ground while trying to start it. when you hear it try to turn over after the remaining gas is burnt up plug it back in and it should start.
also it may not have enough battery power to start it so try jumping it while doing the above^^^^
Old Aug 1, 2007 | 09:56 PM
S13 hatch's Avatar
yeah i tried that today thanks, i think i need to let it sit and let the fuel evaporate and try again tomorrow so does this happen to your rx7 to or is it just sometimes
Old Aug 1, 2007 | 09:59 PM
S13 hatch's Avatar
i got the wires in the right spot and i used a pair of new ngk spark plug i think the fuel overflowed
Old Aug 1, 2007 | 10:05 PM
Rotary7's Avatar
I would pull the plugs make sure no carbon build up to cause bad spark.
Clean with parts cleaner and a wire brush if needed,let air dry
You can also flush the engine out by turning key over from gas/fumes
You dont need to pull any wires.Holding the gas pedal to the floor when starting will do it or pull the egi fuse in the main fuse box in the engine bay.
Turn the key over for a few seconds then put the fuse back in.
Very easy..
If you know how to check the swooshes.
Pull 1 top plug at a time and listen to the swooshes..while cranking the key over.
All of this has to be done on a fully charged battery.
Old Aug 1, 2007 | 10:10 PM
Rotary7's Avatar
I merged both threads...
Old Aug 2, 2007 | 05:24 AM
S13 hatch's Avatar
thanks alot im going to try it today and give you the results
