buzzing sound in fc
Old Jun 8, 2007 | 05:09 PM
Captain Fap'n's Avatar
Fap Fap Fap
Default buzzing sound in fc
alright idk why this started happening but it seems ever since i drove the car home it started buzzing while it sits. like when you start the car all of the sudden it fucing buzzes. if you rev the car or drive the car past 2500 rpms it stops until you come to a stop. the hatch is closed all the fluids are full seat belts are in. i just cant figure it out. i read the factory manual and i checked everything that it said which i stated above.
anyone have any idea on why it does this?
is there maybe a fuse i can pull?
Old Jun 8, 2007 | 07:36 PM
seventhgear's Avatar
hanglike sleeve of wizard
is there a light on the idiot cluster lighting up while the buzzing is sounding? maybe bad coolant temp sensor??<---- big guess
image removed from your sig...see forum rules
Old Jun 8, 2007 | 07:42 PM
Fap Fap Fap
no actually no lights are lit up at all. but i will check the sensor though? where exactly is it located?
Old Jun 8, 2007 | 10:32 PM
rotorjho7's Avatar
Say NO to Rotor Knock!!!
I believe on certain radiators it'll be on the left side i believe from coolant cap, if you're facing engine...you cant miss it its the only wiring running on top of raidiator
R.A.P.S member number #0005
Rotaries
Against
Piston
Swaps
Originally Posted by mikespeed95
Everytime you lift God kills part of mikespeed
"You Lifto, you no dorifto"
No Lift Martyr
Old Jun 11, 2007 | 10:57 AM
Fap Fap Fap
yes it was the coolant sensor. thanks alot man that shit was SO annoying
Old Jun 12, 2007 | 11:30 AM
no prob!!!
