where to rebuild a 13b?
Old Apr 5, 2006 | 01:40 PM
psycho's Avatar
Default where to rebuild a 13b?
So again, I just lost compression on one of the rotors, eventhough I didnt put that many miles on the engine which has 2mm atkins (about 8k miles). Are there any good shops (that wont cost an arm and leg) that you guys recommend around the Tampa area. I need to find why one of the rotors lost compression (I think its oil related) By the way, its an FD with a street port.
Old Apr 5, 2006 | 05:58 PM
Rotary7's Avatar
Get Down-Or-Stay Down
Originally Posted by psycho
Are there any good shops (that wont cost an arm and leg) that you guys recommend around the Tampa area. , its an FD with a street port.
You just lost a leg.
Id recommend you to Scott at Mazsport.
But hes over priced,but the only shop in the area who will work on it.Also FD/and cheap dont ever come hand in hand.
Mazsport
Largo FL
Scott Glassburn
mazsport.net
Do you want to be tazed?
Old Apr 10, 2006 | 07:06 PM
Si-Ninja-Punk's Avatar
TR Balla Donor Supreme
those atkins seals are garbage... i had 3mm and everything else, done by atkins rotary in washington... had low compression within 1k miles... 5gs well spent id like to help you by buying your car for 5k
but seriously, all i have to say is... in the rotary world, you better give that arm and a leg kiss goodbye if you dont learn to do it yourself... i could have retired rich if i would of just put all my money in a ROTH IRA instead of buying that 7... but it was worth it... good luck and sorry to hear that...
Old Apr 10, 2006 | 07:45 PM
psycho's Avatar
Mazsport
Largo FL
Scott Glassburn
mazsport.net
I didnt necesserly mean that i want something cheap. At the same time im not looking for someone overpriced. I would LOVE to get my car done at Mazsport, because I know that it will be done the right way, its just too expensive for me now.
Old Apr 10, 2006 | 07:49 PM
psycho's Avatar
I guess that my only option as of now is to do it by myself. Any help or tips would be much appreciated.
thanks for the replies guys
Old Apr 11, 2006 | 12:32 AM
Rotary7's Avatar
Atikns cheap?
I know alot of people who build drag cars,and they run Atkins.
You wont hear of masny people running RacingBeat any more.
You might find a hand full of people who run Hurleys.But thats about it.
Old Apr 14, 2006 | 06:24 AM
Atikns cheap?
i guess your'e right... just because mine and his where crap doesnt mean everyone elses were... i've heard good thing from the seals but i actually sent my motor to them and i've herd lots of horror stories from atkins... like putting used parts on motors and lots of low comp motors out of the shop... so i'll give you that one... 3mm seals have been holding up good in other cars...
what ever happen to those rotary aviation seals???? have you hurd anything good from them?
Old Apr 14, 2006 | 10:53 AM
TOBYOTA's Avatar
I know people that are running 45 psi on the atkins and they are holding!!! They are cracking the front and rear heads but not breaking the seals. (indio racing) (carlos gonzalas oke) and they both run 7"s in the quater and are putting down over 700 on the dyno.
Very Proud Member of R.A.P.S
R.A.P.S member number #0004
Rotards
Against
Piston
Swaps
http://www.myspace.com/tobyota
