RX8 Rotors in 13b
No way in hell a stock port 6-port motor with the stock FI installed without nitrous is making that much power ...
That isn't SAE corrrected those must be DIN or STD numbers for some crazy ass barometric pressure and altitude or something ...
My stock port Mazda Reman with Intake , Apex'i N1 catback, wired-6-ports and only the alt belt with T-2 Secondaries and an AFC only made 152RWHP ...
Good luck finding 43 more HP with just a header and random block off mods...
I'm guessing you have ported TB , S5 UIM and all the random ish .. I'll give you 10HP tops forall that shit and 10 for the header .. That still leaves you needing to pick up 20+ more hp
Hondata saves lives
Hondata saves lives
Originally Posted by AbortRetryFail
How do you adjust leading and trailing timing separately with just 1 distributor?
I dont like to tell,or show many tricks any more.But if you really want to know,meet up with me at a meet and bring a timing gun.Ill show you
what is the benefit to doing that?
Driving definitions: Understeer is when you hit the wall with the front of the car and Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall and Torque is how far you take the wall with you.
Though you can't have the plugs fire at EXACTLY the same time because of the position of the trailing plug. Too early and it will ignite the next chamber WAY too soon.
Knock Knock.
Who's there?
Detonation.
Detonation who?
KABOOM!
1986 Mazda RX7 GXL - "Champagne"
134.7 RWHP - Going slow in style
Originally Posted by Rotary7
benefits of doing what?
