Stupid noob question.
Old Nov 7, 2005 | 04:58 AM
AbortRetryFail's Avatar
Trunks are for corpses.
Default Stupid noob question.
Ok yesterday i flushed the radiator on my car and i think i mixed too much antifreeze in... it's probably 75% There's a bottle of water wetter in there too.
Is that gonna mess anything up? or will it just make it that much less likely to rust the plates?
1986 Mazda RX7 GXL - "Champagne"
134.7 RWHP - Going slow in style
Old Nov 7, 2005 | 10:19 AM
Puto's Avatar
El Puto ©
Im pretty sure coolant should be about a 60/40 mixture of it and h20, Ive heard of ppl putting in pure coolant in their cars with out any fuck ups, Im sure you will be fine. as for water wetter, I myself have never used it so I wouldnt be able to tell. It reduces coolant temps so I think it may be something good to stick in your rex lol.
Old Nov 7, 2005 | 12:05 PM
Rotary7's Avatar
Get Down-Or-Stay Down
The plates are iron,they will rust a little
Water wetter is garbage on a rotary,dont just go throwing shit in the engine that You have no idea if its good or not,keep in mind of the aluminum rotor housings.
If your worried about engine temps,make sure the car has a belly pan.You have seen the one I made for my FB and Joes FC,it helps with dropping the temps alot..
If yoru not satified with that,get an E fan.
An upgrade thats worth it and you wont regret it.
I dont know what OEM specs for collant in a rotary is,but on a empty radiator,I have always used 75% to a full gal of the 1 gal jug,and top it off with water.
DO NOT use Dexacool (the orange coolant)
Do you want to be tazed?
Old Nov 7, 2005 | 10:01 PM
rexaholic7's Avatar
I BURN OIL N I LIKE IT!!!
the belly pan shit is very very true. i wuz lucky enought to find a stock one with the slits and it works B-E-A-UUUUTIFULLY. oh and if you decide to get an efan. i have one from a v6 taurus and if you do remove the damn plastic shroud dat also helps.
Originally Posted by jonBODON
that guy has more skill in his left pinky toe then your whole body...
Very Proud Member of R.A.P.S.
R.A.P.S member number #0003
Rotaries
Against
Piston
Swaps
Old Nov 8, 2005 | 12:44 AM
Rotary7's Avatar
I told you long ago the stock fan shroud is garbage with an e fan,you said your "mechanic" friend said it was good.
Old Nov 8, 2005 | 02:09 PM
rexaholic7's Avatar
yes u did
Rotaries
Against
Piston
Swaps
Old Nov 8, 2005 | 02:32 PM
What's the matter with the Dexacool stuff? that's what the car had in it for a long time.
Old Nov 8, 2005 | 02:35 PM
Rotary7's Avatar
That was made for certain GM engines,notice how them engines cant use green collant.I just heard dexacool will eat the aluminum in the rotor housing water jackets..
I wouldnt try it to confirm it or not.
Old Nov 8, 2005 | 02:45 PM
Rotary7's Avatar
http://fc3spro.com/TECH/MODS/COOL/ctype.htm
enjoy
Old Nov 8, 2005 | 03:31 PM
Ah shit. Looks like i get to flush it out again soon.
