Electric fan ??
Old Aug 13, 2005 | 01:56 PM
T61turboII's Avatar
Default Electric fan ??
What fan are you using on your ride?? I just put my front mount on and i am thinking of puttin a 2500cfm fan on or better i rode around and it ran a bit hot but when i open my hood it goes down...what cfm fan are you using..any help would be appreciated..
Old Aug 13, 2005 | 01:58 PM
Rotary7's Avatar
Get Down-Or-Stay Down
Do you have a stock radiator?
If so,then just get a Ford Taurus 3.8 e fan.. I have one ill trade something to you for..
If you have a fluidine or koyo,buy a nice fan with manual thermostat.. also do you run the stock belly pan? it does help with cooling..
Do you want to be tazed?
Old Aug 13, 2005 | 02:26 PM
T61turboII's Avatar
I have the fluidine how ever you spell it haha.. i want to get a high cfm fan so if i go to orlando i dont want it to run to high...
Old Aug 13, 2005 | 03:38 PM
Rotary Buddha's Avatar
zero pistons
flex a lite black magic 150 comes with all the relays thermostat and wires needed to do a proper efan install. been running it on my na for over a year now and couldnt be any better. plan to use on my t2 once it runs better.
Originally Posted by rotarykidd
you have no idea how many TR members id kill to have this car for just a day...
Old Aug 13, 2005 | 03:59 PM
T61turboII's Avatar
where did you get it from..the fan I am looking at is like 300 or so..
Old Aug 13, 2005 | 05:20 PM
Rotary7's Avatar
if u had the stock radiator,the 3.8 is enough for what you need and you wont be braking your pocket.. but I wouldnt put that on a fluidine.. try to look for a fan that has more of a shroud on it.. and the manual thermostat
Old Aug 14, 2005 | 04:47 AM
T61turboII's Avatar
i have my stock shroud and and uprgraded e-fan.. it works good but now with the front mount its a bit higher and i want it to stay low.. i see a few pics of a carbonfiber thing that goes on top by the hood latch i might invest in one of those..
Old Aug 14, 2005 | 04:48 AM
zero pistons
http://www.secoperformance.com/ they are a distrubtor of flex a lite products call them up i think it was under 300 and their is one in georgia so it only took 2 days to ship normal ups ground.
Old Aug 23, 2005 | 10:02 PM
StricklyOldskool's Avatar
S.O.S Productionz
Everyone goes with Flex-a-lite..... i guess go with what you know.. I have been suggesting SPAL electric fans...very thin and pull alot of CFM. I have been running a SPAL ran on my turbo setup with a OEM style radiator with a 180 degree thermostat. This also includes the heat from the turbo seeings I have the water cooled center section. I have yet to have a heating problem.
Old Aug 26, 2005 | 01:01 AM
Rotary7's Avatar
he got a fan,I hope he gets it on
