Turbo 2 question
Well my motor finaly has been finished and i went for a test ride.. It rides great only problem is that i put 720s in and they were flooding my motor.. so i end up putting back the stock and it runs fine.. why would this be i am street ported with a hybrid turbo and full exhaust and runnin 10psi.. i was told i would need them.. i think i need some tunning can a stock ecu be tuned.. i also had a fpr put in with a guage and at idle im at lil under 35psi is this where i should be.. If someone can help me out please let me know its goin to be my weekend fun car dont realy have time doring the week to mess with it.. hope i can get it all settled this weekend..
did you put the 720's in the primary or secondairy injector rail? If they are your primaries you are going to flood it alot. The primary injectors are on the bottom rail and the secs. on top. Just take a look to see where the 2 720's are located, they won't look stock.
they were on top and when i went for a ride it was stumbleing real bad i actualy had to change my soark plugs.. so i took them out and its running fine now but after its fully broken in im goin to be putting a pt 61 in and a front mount.. i just thought i would need them for the port and turbo upgrades i did.. I also cant seem to find someone who tunes rx7s at least my air fuel ration or somthin i dont think my fuel is right..
yeah i am running the stock ecu.. i had a fcd put on just in case.. with my stock injectors it revs real clean.. but i think my fuel should be more than 35psi. i thought it should be at like 42 or so
now i got a plate so i take it on the rode runs fine under boost but when i boost my gauge shows lean. now when i had the 720's in my o2 sensor was out but i finaly got it on do u think that could be the reason my motor was floodin out.. and should i try to put the 720s back in.. im goin to get a rtek 7 for now till i decide witch stand alone i want.. do u think this is safe..
O2 sensor was the problem for sure. I'm running a very similar set up to you. However at 10psi I just ran stock injectors. I have the 720cc secondaries in now and run 16psi. I also have a Feed HKS FCon. If you need your car tuned Mazsport in Largo is pretty good. Only rotory place in Central Fl. I will go to.
I been contacting mazsport to get my lt8 from them and tuned but the times they are open i am working and im not able to call.. I emmailed them and he asked me to call and i just wanted to know the price of the stand alone and the tunning and i havent gotten a word back from them..
Scott quoted me like $1600 I think for the Microtech and a base tune installed.
