88 GTU problem
Old May 19, 2005 | 02:43 PM
CoRDiTe's Avatar
Not Mad
Default 88 GTU Problem Also Aluminum Motor Mounts WTF ??? " Read last page "
I have an 88 GTU... Problem is after removing the Pollution pump I only have two belts now on the car. The power steering and the Alternator. After removing the Pollution pump belt and the pump, The motor after revving it to 2500rpms it makes a Grinding noise like if your scratching your nails on the CHalkboard. I removed the belt for the power steering pump thinking that was the problem but it still continues, I also removed the alternator belt and played with the alternator but i dont hear the noise comming from there, Any suggestions what it could be ? I am thinking its the water pump, but the car is not over heating, and the water is circulating. Also its a new water pump but the down size the car has been sitting for a year, but i start it once in a while and let it run for like 5-15 minutes.
Suggestions please......
- CoRDiTe
Old May 19, 2005 | 03:06 PM
AbortRetryFail's Avatar
Trunks are for corpses.
Checked the usual to make sure it's not the tranny/clutch/TOB/etc?
My throwout bearing made that noise
when you took the alt belt off did you turn the water pump and see if it turns smoothly?
1986 Mazda RX7 GXL - "Champagne"
134.7 RWHP - Going slow in style
Old May 19, 2005 | 07:34 PM
rexaholic7's Avatar
I BURN OIL N I LIKE IT!!!
um when u remove the air/polution pump the water pump pulley slips a lil all u gota get is a belt small enough to pry it in between the water pump and the main pulley. do dat maybe datll elliminate the noise. if you want the exact size and number of the belt ask rotary budha i beleive he has that setup in his fc.
Originally Posted by jonBODON
that guy has more skill in his left pinky toe then your whole body...
Very Proud Member of R.A.P.S.
R.A.P.S member number #0003
Rotaries
Against
Piston
Swaps
Old May 20, 2005 | 04:16 AM
yeah he does, he told me what the belt number was but i forgot... I think it's for some air compressor or something...
Old May 21, 2005 | 01:17 AM
Rotary7's Avatar
Get Down-Or-Stay Down
That belt set up,is only for the water pump,You will also get get alt slippage..
Get the dual groove alt pulley..
When you rev it,does it get louder,you cant tell if its in the tranny or the engine?
Do you want to be tazed?
Old May 23, 2005 | 02:32 AM
Rotary Buddha's Avatar
zero pistons
BS on the alt slippage. i have the water pump belt for over 9 months now and never have i once had an experience in alt dropping voltage. plus im running an efan and the crane hi-6 to high load electronics.
the number is 3L220 you can get it from MSC
http://www1.mscdirect.com/CGI/NNSRIT...PMPXNO=2247796
Originally Posted by rotarykidd
you have no idea how many TR members id kill to have this car for just a day...
Old May 25, 2005 | 01:45 PM
CoRDiTe's Avatar
Not Mad
It was the Belt, waterpump. The waterpump seized, after that the alternator belt busted in a zillion pieces, after that no water was curculating, so the Radiator busted on the top tank. So if any1 has a spare Radiator let me know. Im in desprate need of a radiator, its my daily driver. I need a RADIATOR A.S.A.P
-CoRDiTe
Old May 25, 2005 | 01:58 PM
... check the copher's in clearwater, i think there's still an RX7 there
Old May 25, 2005 | 02:02 PM
CoRDiTe's Avatar
Not Mad
Thanks for the info but it's Way too far away from me as of right now. Plus I get off work too late and cophers closes i think at 5.
- CoRDiTe
Old May 27, 2005 | 01:15 AM
Rotary7's Avatar
I dont know how you can call BS,if you havent experianced it.. I have,and this is why I now run smaller belts on all my alts,cause the stretch like a bitch,and dual pulley for the alt helps the slippage,
