86 rx7 problems
Old Nov 1, 2004 | 07:08 PM
jdmfreak100's Avatar
Default 86 rx7 problems
aight when the car idles its good it stays on cold but when i go drive it after like 15 20 min it will start to overheat i checked the water pump its good but i think the radiator is cloged up cause i can keep the car running at an idle for 2 hrs befor it starts too even heat up half way its just when i drive it .... it will over heat i checked all my hoses and my apex seals are good cause i still have the same power i had befor it started overheating any sugestions
Old Nov 2, 2004 | 01:28 AM
Rotary7's Avatar
Get Down-Or-Stay Down
Default Re: 86 rx7 problems
Does it blow white smoke?/ if so blown coolant seals,
Are you loosing coolant?/if so check hoses,radiator,heater core/ etc etc
How about the thermostat?
Why do you think the rad is clogged?
Do you want to be tazed?
Old Nov 2, 2004 | 09:01 AM
the keeps on over heating and it seems as if when the car is being driven water isnt being pushed throught he radiator and pressure is causing increased temperature. we think it may be either the radiator or the water pump. could you tell us what the problem is and how to fix, as well as how much it will cost.
Old Nov 2, 2004 | 01:50 PM
Rotary7's Avatar
Its hard to say whats wrong just by explaining it ,I had a friend years ago,who did everything to his car to fix the overheating problem.. well it had bad seals..
Keep in mind,the more you overheat that engine,the chance your housings,and plates wil get warped..
You might want to start looking towards a rebuild..
the water pump is easy to change,if you do that get the thermostat changed,and rod out the rad if its real bad..
But I still think its the seal..pull out some plugs,are they white on the ends?wet with coolant?do you smell burning coolant with the car ideling?
