Check Engine Light
Old Aug 4, 2004 | 02:38 AM
Pineapple's Avatar
Drift Session
Default Check Engine Light
I just checked why my engine light is coming on and it's giving me a code 12, which is the throttle sensor-full range. I have been looking around the throttle body for some wires disconnected and found nothing but a big black (probably ground) wire cut. I'm pretty lost about this and the light goes off every once in a while then comes back on. Any help? Thanks.
Old Aug 4, 2004 | 04:54 PM
Mongoose's Avatar
If you live in Tampa, call Maztech at 874-0937. They can help you since they fix RX7s and they rebuild rotary engines
Old Aug 4, 2004 | 06:12 PM
Rotary Buddha's Avatar
zero pistons
tps is out of wack. tune it. i thought i talked to you about it before.
Originally Posted by rotarykidd
you have no idea how many TR members id kill to have this car for just a day...
Old Aug 4, 2004 | 07:18 PM
seventhgear's Avatar
hanglike sleeve of wizard
well that wire you found... if it is a ground please make it a working one and sounds like a tps prob to me too
image removed from your sig...see forum rules
Old Aug 5, 2004 | 10:54 AM
Pineapple's Avatar
Drift Session
Ok, thanks for the help guys. I posted this up before I talked to you Tory, after I posted this up. So thanks to everyone who is helpful.
