TII at the JUNKY!!!
Old Aug 1, 2004 | 04:13 AM
taka86fc's Avatar
Turbo>NA
We need to see another side of the motor. Did you get other necesary parts for TII conversion?
1998 J-Spec Z28 convertible (daily driver)
1991 240sx (U.S drift beater)
1990 SILVIA (JP drift beater) SOLD
1990 R32 Skyline (RB25 powered )GONE
1987 Toyota Corolla GTS (NEVER DIE)
anti-oval drift association
Old Aug 1, 2004 | 06:00 AM
Rotary7's Avatar
Get Down-Or-Stay Down
if you think the motor is stock,and has no intake or exhast manifolds.... if the engine has nto ben cracked open the easiest way to find ut if its a N/A or Turboed is ook into the exhst ports...
Do you see baffels?If so its N/A if not.. then you have a good chance its a Turboed,its you paid that much for a 6 port . im sorry..
Why didnt you take a pic of the car at the yard?Run a basic car fax on the VIN,it wil tell you what it is..
Do you want to be tazed?
Old Aug 1, 2004 | 11:01 AM
seventhgear's Avatar
hanglike sleeve of wizard
turn the crank over a few times listen for compression"wet pussy farts" out of both front and rear exhaust ports.... toss a lil ATF in the spark plug holes while your turning the crank and see if you can get some quiefs outta it
image removed from your sig...see forum rules
Old Aug 2, 2004 | 11:17 PM
xiffa2003's Avatar
RuNNitBiTcH
It cranks over, but my bet is that it isnt a T2!!! I checked out the injectors (got the info from rotaryresurrection.com) and the red ones came on the 86+ N/A. "Left without a paddle, floatin shit's creek!"
Anyways, earlier tonite i started to strip the engine down to the block to see if I could salvage anything. Most of the crap on the engine was all original crap, and most of the bolts had never been turned. This one might not be as bad as i thought.
SOMEONE HELP ME!!! Do I rebuild with turbo internals, or do I ease the stress with a bit of self gratification (if i spelled it rite) and find T2 parts?? I NEED ANSWERS GUYS!!!
suggs salvage has done it again, another fucked customer
02 CBR 954rr for sale 5000 or take payments
Old Aug 3, 2004 | 02:29 AM
Pineapple's Avatar
Drift Session
Sorry to hear about it. S5 N/A's aren't that bad at all, but if you want to go turbo, I'm not too sure what you can do. Good luck, sorry it didn't work out.
Old Aug 3, 2004 | 05:03 AM
813kr$'s Avatar
go FAQ urself . . .
You can boost any N/A rotary ! ! !
Just got to tune, I hear if you keep it at 12 psi or under you should be reliable. Their is a 12a with stock rotors that pushes like 680 HP at about 28 psi ! ! !
Old Aug 3, 2004 | 01:35 PM
  #17 (permalink)
Rotary7's Avatar
Ok explain to me how to turbo a 6 port.. and why would you?
Old Aug 3, 2004 | 04:34 PM
  #18 (permalink)
Rotary Buddha's Avatar
zero pistons
high compression rotors + turbo = dead rotary. its not worth the trouble it can be done. but safe bet is 8 psi. its a lot easier and cheaper to swap in a turbo motor than to turbo a n/a. http://www.aaroncake.net/RX-7/naturbo.htm
Originally Posted by rotarykidd
you have no idea how many TR members id kill to have this car for just a day...
Old Aug 4, 2004 | 04:59 AM
  #19 (permalink)
813kr$'s Avatar
go FAQ urself . . .
Fuck a 6 port ! ! !
but you can put a turbo on anything . . .
12a Power
