Adjust timing
Old Jul 21, 2004 | 07:45 PM
Big Chris's Avatar
tampa car scene
I put vaccums on it and it has no cats.
Old schooler.
Old Jul 21, 2004 | 08:19 PM
Solar Specialist's Avatar
SOLAR-SPECIALIST.COM
Huh? You put vacuums on it? No, does it have any vacuum leaks? They are very tough to nail down or even be sure that you have them some times. Hows the idle?
Old Jul 22, 2004 | 03:18 AM
Big Chris's Avatar
tampa car scene
New vacuum lines, idles at 1,500, idle is ok.
Old schooler.
Old Jul 22, 2004 | 04:50 PM
8716v's Avatar
check to see if the secondary ports are working correctly. they work off vacuum and they could be stuck closed or open. that would make a big difference to performance.
Old Jul 22, 2004 | 04:56 PM
Rotary7's Avatar
Get Down-Or-Stay Down
5th and 6th ports? stuck open wouldnt give him that problem..
Do you want to be tazed?
Old Jul 22, 2004 | 05:15 PM
Ya it would tony. When they are stuck or wired open you lose your low end at least some.
Old Jul 22, 2004 | 05:38 PM
  #17 (permalink)
Rotary7's Avatar
Car has no power under 4 grand in every gear. Back fires above 5k and will not accelerate in 5 gear at all.
what does he mean no power @ 4k.. I know you loose bottom end.. but how bad is it..
I have not seen a car,that has wired 5th and 6th port to cause back fire and no accel..
anyways.. these are reasons why I think 6 ports are pos..
Old Jul 22, 2004 | 05:45 PM
  #18 (permalink)
Big Chris's Avatar
tampa car scene
I think they are working, vacumm is conected and moves freely.
Old schooler.
Old Jul 23, 2004 | 11:38 AM
  #19 (permalink)
8716v's Avatar
well maybe it has something to do with your screan name
Old Jul 23, 2004 | 11:57 AM
  #20 (permalink)
Big Chris's Avatar
tampa car scene
If it does then the car is out of luck.
Old schooler.
