Adjust timing
Originally posted by 93g2integra Chris
I put vaccums on it and it has no cats.
Huh? You put vacuums on it? No, does it have any vacuum leaks? They are very tough to nail down or even be sure that you have them some times. Hows the idle?
Originally posted by superrx-7
check to see if the secondary ports are working correctly. they work off vacuum and they could be stuck closed or open. that would make a big difference to performance.
Car has no power under 4 grand in every gear. Back fires above 5k and will not accelerate in 5 gear at all.
Originally posted by Ryde _Or_Die
Ya it would tony. When they are stuck or wired open you lose your low end at least some.
I have not seen a car,that has wired 5th and 6th port to cause back fire and no accel..
anyways.. these are reasons why I think 6 ports are pos..
