rough idle
Old Mar 25, 2004 | 02:36 AM
ProjectRedSuns's Avatar
Default rough idle
im experience some rough idle conditions. should i just adjust the idle control on the throttle body. or could it be something else. temp is usally a quarter or at most a half. but when i start to move it goes away.
Old Mar 25, 2004 | 05:29 AM
seventhgear's Avatar
hanglike sleeve of wizard
is it only at cold start up? all the time when you are idling... try to explain yourself with the utmost details u can.. it will make for an easier response..... what is it idling at when its rough? really low? if so then adjust the idle control screw a bit... get your tps adjusted correctly.. a member of fafracing happens to have the tps analyzer deal... if you want to talk to him his name on here is mizike ...but for now just gimme more details...
image removed from your sig...see forum rules
Old Mar 25, 2004 | 06:45 AM
its a rough idle all the time. its run around 500 rpm sometimes will drop to 200 or 300.
Old Mar 25, 2004 | 08:38 AM
813kr$'s Avatar
go FAQ urself . . .
Damn, that is a low idle. Bring your idle up higher and it should smooth out some. Shit, my engine wont idle at 500 rpm's, it will just die out!
Old Mar 25, 2004 | 10:32 AM
FCDrifter's Avatar
Gallery on TR Sucks
yeah my idle when i had my car was like 700-1000 depends on what the conditions were at the time
adjust you screw and that should help out some
email at FCDrifter@gmail.com
Old Mar 25, 2004 | 04:52 PM
Levi's Avatar
sound slike the timing and TPS are wacked out, the idle mixture screw will not fix your problem, it the TPS.
You need to come over to my house and get the car adjusted correctly. We do have that tool for this purposes.
custom parts is our perfection.
Old Mar 26, 2004 | 02:48 AM
i got a lot of work to do on my car tonight change brake rotors, brake pads, change oil + filter, replace belts, and ill try the idle screw. if that doesnt work maybe tomorrow i can meet up with you levi.
Old Mar 26, 2004 | 04:17 AM
is it idle surging?
