89 RX7 motor in miata?
Old Oct 29, 2003 | 07:55 PM
stockCRXsi's Avatar
Default 89 RX7 motor in miata?
Anyone knows if an 1989 RX7 turbo motor will fit into a 1993 miata. Is this posible? has it been heard of before?
My friend got a really good deal on that motor and he's trying to find mounts and wire harness to get this motor in his Miata.
can anyone help me out?
Old Oct 30, 2003 | 07:19 AM
seventhgear's Avatar
hanglike sleeve of wizard
ALL OF IT WILL BE CUSTOM AND yes its possible...... search the mazda forum for a thread by me on that exact topic. or go to rx7club.com and serach on there i have many posts on it there
jack
image removed from your sig...see forum rules
Old Oct 30, 2003 | 07:44 AM
BacardiRon's Avatar
Z32 Tech Bitch
You need to weld in a sub frame to hold everything in place and then use a stand alone to run the motor. The RX ECU and harness will run the motor fine but none of your gauges will work and I'm not sure what else may be effected(lights, horn, etc.). Its doable but ts not cheap. A Flyin' Miata kit would be a better option if your friend is in dire need for more power. The B6 can take quite a beating and can make more power then most people should be able to have in a 2000lb car.
Tibby - Ex Sonic rusted muffler pimp
Old Oct 30, 2003 | 09:08 AM
hes right i know of someone that is already up to $10k and not done...
peace
jack
Old Nov 11, 2003 | 01:01 PM
Rotary7's Avatar
Get Down-Or-Stay Down
anything is possible.. im thinking of putting a 12a on the back of my GoPed...
Do you want to be tazed?
