Official evo 8 - 9 weight reduction thread
Old Apr 18, 2010 | 09:59 AM
B-Spec's Avatar
Toonz Stuff
Default Official evo 8 - 9 weight reduction thread
Evo 8 and 9 weight reduction thread
Special thanks has to go out to David Buschur for adding a great deal of info to this weight reduction thread. this is what brings a great community together.
We all know the evo 8 and 9 weigh a lot. Most of us would like to lighten them up a little bit. So post up your mods you have done to reduce the weight of your evo. Cutting the car up is not allowed here.
There are many mods we can buy that reduce the weight of the evo. There is also many freebie mods we can do to also reduce the weight of the evo. With that said lets make an official thread with what was done and how much was saved on your evo.
The Rules:
1. Post up what you have done for freebie weight reduction with just a little write up on how you did it and I will add your post # next to the mod on the list for others to use as a how to and better searching.
2. Post up what you have purchased that was either weight reduction related or just a part that was lighter then stock. PLEASE try and get the full weight of the stock part that was replaced for a better comparison
3. Last and most important how much lighter was your modification whether it was a freebie or a purchased part.
I have made a list below for all to view as we gather info. I will update it regularly as long as it was a legit mod and something we all can do
Freebie parts removal and mods list
Spare Tire, Jack, and Tool drops 37 lbs ''carpet and lining 4 additional lbs'' ''see post # 11 for how to info''
Intake Bracket & EGR drops 5lbs
FMIC Sprayer Bottle drops 5.4lbs (empty) 11.5lbs(full)
Firewall Sound Deadening drops 14.2 lbs ''rubber pad''
Floor Mats drops 5 lbs ''all 4''
Brake dust shields drops 1.5 lbs
A/C Fan drops 6.4 lbs
AC Bracket drops 4 lbs
Compressor drops 14.1 lbs
Condenser w/ lines drops 9.8 lbs
Evap / Purge Stuff drops 9 lbs
Catalytic Converter drops 10.5 lbs
rear evo 8/9 wing drops 7 lbs
Rear Seat (bottom) drops 9.5 lbs
Rear Seat (top) drops 14.5 lbs
Rear speakers drops 8.8 lbs
Wiper Fluid Tank empty ???? full drops 8.3 lbs
Rear Wiper Assembly drops 5 lbs
Front strut tower brace drops 8lbs
3 under dash/steering column brackets drops 3 lbs
full E brake assembly ''backing plates, cables, full E brake assembly/mounting bracket drops 10 lbs ''NOTE'' you will not have an E brake for the street driven evo's
Heater core drops 10 lbs
Blower motor assembly drops 5.5 lbs
exhaust heat shield above the drive shaft drops 2 lbs
sound deadening under carpets ,,black tar looking stuff'' drops 11lbs if ALL of it is removed from floor, fire wall, under rear seats
2 cross braces and bolts from K member saves???????
Front Bumper Support drops 13lbs NOT RECOMMENDED
Rear Bumper Support drops 17 lbs NOT RECOMMENDED
Driver Side Airbag drops 5 lbs NOT RECOMMENDED
Passenger Side Airbag drops 6.1 lbs NOT RECOMMENDED
Rear Seat belts drops10 lbs NOT RECOMMENDED
Aftermarket ''purchased'' weight reduction/lighter then stock parts list
engine/drive train
1. AMS power steering delete kit - saves 11 lbs
2. AMS front cross member - saves 7 lbs from the stock cross member
3. AMS rear Mustache Bar Eliminator kit - saves 13 lbs
4. Buschur Racing rear differential support "mustache bar" - saves 12.7 lbs
5. Buschur Racing Side Differential Support bracket - saves 5 lbs from the stock side diff brackets
6. AMS lightened drive shaft - saves 14.5 lbs ''12 lbs rotational savings''
7. AVID passenger side motor mount - saves 2 lbs from the stock motor mount
8. Torqline CTG Carbon Fiber Driveshaft - saves ???????
9. CBRD light weight radiator WITH FAN saves 11.5 lbs WITH OUT FAN saves 12.5 lbs over stock
10. Buschur Racing/Fluidyne small radiator saves 6.8 lbs from stock radiator
11. AMS small/half size radiator kit with 12 inch spal fan saves 10 lbs over stock ''with stock fan''
exhaust
1. AMS turbo back exhaust saves 20lbs over the stock TBE
2. Buschur Racing turbo back exhaust saves 37 lbs over the stock TBE
exterior body
1. 4. AMS carbon fiber roof - saves 45 lbs with sunroof - 16 lbs without sun roof - 7 lbs RS/MR roof
2. Downforce composites carbon fiber hood weighs 11lbs ''7.5 lbs lighter then stock hood''
3. Downforce composites carbon fiber trunk weighs 7 lbs ''15 lbs lighter then stock trunk''
interior
brakes
1. Giro Disk 2 piece ''aluminum hat'' front rotors saves 4 lbs PER side ''4 lbs rotational savings'' over stock rotor's
2. giro disk 2 piece ''aluminum hat'' rear rotors saves ????????
3. AMS/Wilwood Lightweight Brake Kit ''Front'' saves 32 lbs ''22 lbs rotational savings''
4. AMS/Wilwood Lightweight Brake Kit, ''Rear'' saves 22 lbs ''17 lbs rotational savings''
suspension
1. Apexi N1 coil overs weigh 34 lbs ''saves 31 lbs over stock''
2. Tein double adjustable aluminum coil overs 46 lbs ''saves 19lbs over stock''
3. HKS Hypermax weighs 46.8 lbs ''saves 18.2 lbs over stock''
4. Tein Super Street coil overs weighs 52 lbs ''saves 13 lbs over stock''
5. MAGEN Racing coil overs ''street'' weighs 45 lbs ''saves 20 lbs over stock suspension''
Future parts we would like to see made from our vendors for more weight reduction
1. front evo 8/9 tubular k member
thanks to dave for the following. thats a huge bitch. i mean list
Stock EVO exhaust, 60 pounds.
BR 3" turbo back offroad exhaust, 23 pounds
BR 3.5” turbo back w/Burns race muffler, 27.4 pounds
Stock under tie bars (2) with bolts, 2.5 pounds
BR battery kit, 17 pounds
Stock EVO battery, 37 pounds
Front bumper beam, 13 pounds
Rear bumper beam, 17 pounds
Jack, tool, spare tire, 37 pounds
Intake bracket and EGR valve, 5 pounds
ACD Unit in front fascia, 25 pounds
Rear window, 13.5 pounds
Front window, 25 pounds
Lexan front, 8 pounds
Lexan rear, 6.3 pounds
I/C Spray bottle, empty 5.4 pounds, full 11.5 pounds
Rear washer bottle, empty 8 pounds
BR intake, 4.1 less than stock
Interior carpet padding and misc brackets, 17.5 pounds
Rear fuel tank evaporator, 8.5 pounds
A/C compressor and condensor, 29.6 pounds
Steering column plastic/meal insert, 1 pound
Magnaflow muffler w/tip 11.4#
Bullet muffler w/tip 6.7#
Stock radiator, 9.7 pounds
Small fluidyne radiator, 6.8 pounds
RS non-power mirror, 2.4# with nuts
Wiper motor and wiper arms, 7.7#’s
Race FMIC, 27.1#’s
BFIC, 29.9 #’s
Street FMIC, 23.7#’s
Stock EVO8-9 FMIC, 10.8#’s
Stock driveshaft w/carriers attached, 27#
DEVO driveshaft also complete, 16.2#
CCW wheels w/o spacer 16x9, 17.5 pounds
CCW's with Hooser QTP 26x9.5x16, 34.4 pounds
SSR's w/Trampio's, 39.8 pounds each
SSR's with Neova's, 42 pounds each
EVO 9 wheel, 20.2 pounds
BFG Drag radial 225-45-17, 23.2 pounds
TSW 18” wheels w/Mickey Thompson 245-40-18 drag radials, 45# each
Volk TE37 18x8.5 +40mm, with Nitto 555R 255-35-18, 43.4#
*245-40-17, largest tire that will fit on EVO without fender rolling
League 17x8.5x17 with M/T motorcycle slick, 32#
Stock EVO8 with M/T motorcycle click, 32.2#
CCW's w/26x10.5x16 M/T ET Streets, 39.1#
Stock side differential support, 4.5# each
BR billet side diff support, 2# each
Rear differential aluninum bushings 1.3 pound
Stock front center member, 9.4 pound
BR center member, 2.9 pound
Stock mustache bar, 15.9 pound
BR mustache bar, 3.2 pound
Stock EVO8 rear control arm 7#
AP adjustable control arm 6.3#
BR Seat lower brackets, -2# total doing both seats
Stock EVO8 strut tower bar, 7.3 pounds
DC Sports titanium bar, 2.4 pounds
DMS 50 mm suspension 58.2 pounds
Stock EVO suspension, 64.6 pounds
Tein Super Streets, 52 pounds
Tein DBL adjustable aluminum, 46 pounds
Apexi N1's, 34 pounds (10 pounds ea. front and 7 pounds each rear)
Meagan Racing coil over 12.3# front, 8.6# rear
HKS Hypermax Front 13.7#, rear 9.8#
Apexi S1’s, 51 pounds, 15.2# front, 10.3# rear
D2’s, front 10.8 #, rear 7.5#
Robispec (Fiber Images) hood, 9.9 pounds
trunk, 9.5 pounds
trunk skin, 4.4 pounds
VIS carbon fiber hood, 21.6 pounds
Stock EVO hood, 20.2 pounds
VIS carbon fiber trunk, 11.9 pounds
Stock trunk lid, no wing, 22.5 pounds
Stock trunk lid with factory wing 28.8#
Stock front rotor, 21.35 pounds
Stock front caliper, 10.5 pounds
Stock rear rotor, 14.6 pounds
Stop Tech, 335 mm rotor, 17.5 pounds
Stop Tech, caliper, 11.5 pounds
Giro Disc front rotor, 17.4 pounds
Giro Disc rear rotor, 11.1 pounds
Giro Disc front drag rotor, 13#
Giro Disc rear drag rotor, 9#
Performance Friction front rotor, 17.8 pounds
Project Mu front rotor, 18 pounds
Bear front rotors, 15.8 pounds
Wilwood front rotor, 10#
Wilwood rear rotor, 6.4#
Baer Eradi Speed front rotor, 15.5#
Baer Eradi Speed rear rotor, 11.4#
Stock 2 liter crankshaft, 31.5 pounds
Stock 2.4 liter crankshaft, 35.5 pounds
2 liter crank with counterweights cut down 30.5 pounds
Will be constantly updating with new info.... Stickey???
Just another guy with a laptop addicted to forced induction.
JoKie Tuning
Ray's
Performance
Machine
813-368-8006
B-Spec Tuning
813-451-7547
Old Apr 18, 2010 | 10:01 AM
SuburbanNoize's Avatar
Cold Ass Honky
Got it for ya
TR DC CREW MEMBER #4
StricklyMT.com
Performance Specialist
727-510-6301
Old Apr 18, 2010 | 10:03 AM
B-Spec's Avatar
Toonz Stuff
That was fast!
JoKie Tuning
Ray's
Performance
Machine
813-368-8006
B-Spec Tuning
813-451-7547
Old Apr 18, 2010 | 10:05 AM
Cold Ass Honky
<-Is on it
StricklyMT.com
727-510-6301
Old Apr 19, 2010 | 12:22 PM
cuco's Avatar
500+ hp club
Originally Posted by SuburbanNoize
<-Is on it
u are the man dave, thanx
EG-6 500+whp alpha tuned
JOKIE TUNING
INDUCTION PERFORMANCE
RI AUTOMOTIVE
Sharp custom coatings
WicKed WayZ 4 LYFE RIP
HoG3TT3R & MADDAD
Old Apr 19, 2010 | 12:23 PM
cuco's Avatar
500+ hp club
nice find billy
JOKIE TUNING
RI AUTOMOTIVE
HoG3TT3R & MADDAD
Old May 20, 2010 | 11:59 AM
cuco's Avatar
500+ hp club
going to close this!!
JOKIE TUNING
RI AUTOMOTIVE
HoG3TT3R & MADDAD
