Lexus Gs300 Engine Service
Old Feb 19, 2011 | 04:47 PM
Hybrid Motorsports's Avatar
Default Lexus Gs300 Engine Service
Owner Sean:
Came in with the notorious leaky cam seals on his Gs300 2jz-ge vvt-i, while in there we decided to also do the crank (front main) seal...
Cam seals:
Crank seal:
Seals installed:
Now reverse the process: waaalaa!! All done..
CALL OR PM FOR SERVICE FROM MILD TO WILD!!
Hybrid Motorsports LLC.
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
Shop Forum:
https://www.tamparacing.com/forums/hybrid-motorsports/
Old Feb 21, 2011 | 07:04 AM
two_seven_two's Avatar
Good work!
(OO\____/OO) Skyline GTR for sale. Link WITH OVER 40 PHOTOS below.
http://www.modifiedcartrader.com/L/2...an-Skyline-GTR
Old Aug 13, 2011 | 06:25 PM
mab9981's Avatar
i have an is300 that we did the cam seals on. and for some reason i have a very small leak from the bottom timing belt cover.
When we disassembled it, we could see it was the two cam seals leaking ever so slightly. SO we read the Lexus DIY and it called for gasket sealant across the top of the seals. SO we did that and it still has a small leak.
Is there something i'm maybe missing? are you suppose to gasket seal all the way around the gasket?
Thanks for the help.
Old Aug 29, 2011 | 08:15 PM
bikeimports's Avatar
Please refer to your factory service manual or post in Toyota tech section
Thanks
If you do not have fsm or access to one pm me
felix813
May 12, 2010 03:04 PM
ulovemyjdm
Oct 31, 2009 06:38 PM
ulovemyjdm
Oct 12, 2009 05:47 PM
rukkshun
Jan 8, 2009 12:00 PM
LexusKrazzyBoy
Aug 4, 2007 06:19 PM
