Terence's Nissan S13/1jz Swap Build
Well back form the driveshaft shop.... They did a great job btw. Thanks guys.
So with the driveshaft installed we decide to mount the intercooler & run the piping, Then we encountered a comment problem with Jz swapped 240's the throttle body clearance:
Best thing to do is purchase a skyline radiator, but the customer did'nt know, no biggy. (will still require cutting & welding the water neck but will be clean & pretty slick looking)
Second Best thing to do is shorten it:
Justin getting his Tig on:
After:
So now with that done we can move onto mounting the intercooler & running the piping:
After:
Hybrid Motorsports LLC.
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
Shop Forum: https://www.tamparacing.com/forums/hybrid-motorsports/
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
^ Thanks guy's........ well there you go straight from the horse's mouth we'll be at the dyno.
^^ driveshaft shots added in previous post.
Couple new shots of the charge piping / intake done, bov installation.
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
Thanks again man, I'm glad to know your happy...... No your the BOSS.
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
i did the same thing with the throttle body on my 2jz. basically just chop-sawed it. and i also used a ka radiator. all i did was cut down the water neck and point it out straight like so:
Srqspeed.com
-Dane
98 240 w/ bolt-onsSrqspeed.com
