B20b boost or all motor?
Old Sep 15, 2011 | 09:20 AM
s14drifting's Avatar
Default B20b boost or all motor?
whats up TR, i got a b20b in my eg hatch. this is my first time building a b20, so i was wondering what every one thinks is better. boost or building it all motor? i want it to be fast but not blow up after two passes.
thanks
Old Sep 15, 2011 | 09:46 AM
cjackson2802's Avatar
GSR Head, Cams, ARP Studs, MLS Head Gasket, 100 Shot. Gutted. 12 Second car all day. That'd be the cheapest route. Same setup, stock bottom end. Run a 50 trim, around 10 psi, you're over 400hp...then you're talking LSD, Axles, Clutch, Radials....Then it gets pricey ontop of the whole turbo setup.
Old Sep 15, 2011 | 09:52 AM
I got a 50 trim turbo and an turbo manifold, but i heard that b20 sleeves crack all the time with boost
Old Sep 15, 2011 | 09:58 AM
With low boost, GE block guard, and a really good tune....you wont have any problems. Sleeves crack from detonation from retards trying to tune their own shit, or run too much boost. Run a thicker head gasket to lower the compression. Excessive cylinder pressure is also a cause of cracked sleeves.
Old Sep 15, 2011 | 10:03 AM
so what would last longer as a daily driver and a track car on Wednesdays lol goin with the gsr head and cams on a 100 shot. or all that on 10 pounds?
Old Sep 15, 2011 | 10:05 AM
All motor daily driven, 100 shot at the track. As long as it is tuned for the 100 shot.
Old Sep 15, 2011 | 10:06 AM
It can be reliably boosted but like I said...thats where it gets pricey.
Old Sep 15, 2011 | 10:10 AM
yeah i realized that,i got one more question. what clutch and flywheel would u recommend on a 100 shot?
Old Sep 15, 2011 | 10:15 AM
BoostedRacerDad's Avatar
Pops
400 wheelHP with a 50 trim at 10 psi on what fuel?
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
GSR Head, B20 block, Cams + 100 shot will put you around the 250-275whp range. Most likely a stage 2 clutch. Exedy, XTD, ACT, Competition are all good. Stay away from F1 Racing, Gripforce, etc. Fidanza or ACT Flywheel, OEM throw out bearing. If you're spending all this money, and dropping the transmission, you may as well go ahead and find a GSR or B16 LSD Transmission. Will help your track times alot.
