GOING K24 someone help me!
Okay tr 6 cars later I have finally decided to go K.
I am only 17 years old and just need some suggestions from yall.
I bought a k24 long block with 5 speed trannny
Also I have the wiring harness from a rsx will that be good?
I know i can use b-series axels so thats cheap
Im guessing all i need is just motor mounts and ecu
give me any opinions or suggestions tr
Theres more work than just mounts and ECU man. Check out k20a.org
http://www.k20a.org/forum/forumdisplay.php?f=13
You need to find yourself the complete k swap parts list for your chassis.
first you definitely CANNOT use b series axles. You can use rsx type s axles with B series outers but base axles work fine depending on your setup. Before you start this swap I suggest you do yourself some research to save you some time and headaches. You will need a LOT more than mounts and an ecu. Also what K24 did you go with? Hopefully a K24a2 that's the only 2.4 stock motor that would ever be worth swapping in my opinion.
Mattbuilt
AEM | Mugen | Skunk2 | Hasport | Hondata | Koni |Ground Control |
