Need Help!!!
Old May 24, 2010 | 10:33 PM
onejdm90crx's Avatar
Exclamation Need Help!!!
Hey Tr,i Have A 90 Crx Si But Da The Problem Is That It Wont Start I Have Changed The Starter And Bought A New Battery And Den I Checked The Ground Wires To The Battery And Checked The Fuses And Checked The Main Relay Fuse And It Still Wont Start.when I Try To Start It Up It Wont Turn Over It Only Does Click Noise So Tr Please Let Me Know Wat U Think It Might Be Cause Im About To Flip Da Car And Burn It Lol Naw.
TR "Old Skool EF" Member #187
Old May 26, 2010 | 05:07 AM
DC2_BoostKING's Avatar
CRAWFORD BUILT
is the engine grounded to the engine bay?
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old May 26, 2010 | 09:40 AM
yeah is grounded
Old May 26, 2010 | 09:52 AM
CRAWFORD BUILT
check to see if the main relay is working. do you have a volt meter?
CRAWFORD BUILT
DC Crew Member #23
Old May 27, 2010 | 10:05 PM
yeah it works
Old May 27, 2010 | 10:11 PM
lahlahlahliz's Avatar
Attention Whore
I think you may need a new distributor maybe
Old May 27, 2010 | 10:54 PM
Tampa's_Slow_EG6's Avatar
Living in Black & White..
try jumpin the starter if the car starts u have a bad ignition switch..
Old May 28, 2010 | 06:22 AM
all ready did wont start
Old May 28, 2010 | 06:47 AM
CRAWFORD BUILT
ok so is the starter engaging? does the gear pop out and spin or just sit inside the starter housing and spin?
CRAWFORD BUILT
DC Crew Member #23
Old May 28, 2010 | 12:25 PM
Attention Whore
I'm telling you.. I had this same problem with my ef.. I changed the dizzy and it started right up.
