Help A/C question, ASAP, its hot here.
Old Jul 10, 2003 | 02:29 PM
stehigs321's Avatar
Default Help A/C question, ASAP, its hot here.
Ok, i recently did a motor swap into my EK civic coupe (B18c1). My A/C condensor had a leak in it and the A/C was not working what so ever. So we took it and the compressor and some of the hoses that went along with them. I made sure that the end of the hoses for the A/C system that remained in the car were taped up so no dirt got into them. So now i have the condensor, compressor, and some of the hoses that are attached to the compressor out of the car. I just went in to honda today to have them check it out to be put back in. I know i need a del sol vtec compressor bracket. But honda seems to think that after the system is open and sat for a while the entire system may be ruined? Is this possible. I did tape up the ends of the tubes that remained in the car. Can a compressor go bad because i left it out? Or the hoses that come off of it? Or even the ones remaining in the car? Please help.
Old Jul 10, 2003 | 03:07 PM
ToyDoctor's Avatar
Your system should not be ruined. Most all A/C systems have one
componet that is perishable when open to the atmosphere. Your receiver/drier has desicant material inside of it. It's purpose is to
absorb moisture and keep the system "dry". Most techs replace it when servicing the A/C, however I've found if you allow the system to stand at vacuum on a pump for about 1 1/2 hours you should be ok.
Old Jul 13, 2003 | 01:03 PM
00TEGLS's Avatar
That is all correct it just sounds like whoever told you that wants to make money off you or just don't know about a\c systems.
Old Jul 13, 2003 | 02:56 PM
SEEKERone's Avatar
Trialed for Treason
or maybe because they have to warranty the job, they want to do it right the first time.
Old Jul 19, 2003 | 07:43 PM
yolooky's Avatar
If your compresser was left open, you should remove and replace what oil is in it!
Old Jul 20, 2003 | 09:07 AM
00TEGLS's Avatar
If you bring a opened system into a honda dealer you would be lucky to get any warranty, I work for one,I am a\c certified and have my r-12 card.
Old Jul 20, 2003 | 11:15 AM
99B16Si's Avatar
just put all the a/c shit back in your car. make sure theres lubrication in the compressor, go to discount, get 2 cans of r134 and a small can of the oil that is used to lubricate the system, fill it up and call it a day.
Old Jul 22, 2003 | 08:58 AM
letsrollagn's Avatar
BRT OVERKILL
dealerships are always going to be extra carefull, but I have reused components over and over and over again...just ask dave(99b16si) he has an a/c line he got from me in his car right now working great
Why is it when ever I really need to weld something the acetylene always seems to run out...
Only babies drink from bottles...
Boosted 00 Si
N/A 93 HB b16/18
