skunk2 coilover installation
wwondering if anyone has time tommorw nite to help my put some coilovers on...I read the directions and I have done lowering springs on countless hondas, acuras, couple 240s,....blah blah. But anyways when I read the directions it said to have about 22 rubbers seals or bands whatever they're called I have 20.....so im wondering if I need all of then ur what???? and in the picture it didnt really show where to put the rubber pieces. Any help is appreciated. thanx
-Taylor
-Taylor
United States Marine Corps
6322 Comm-Nav Tech
PFC
RAH!
6322 Comm-Nav Tech
PFC
RAH!
bro they are for different shocks people use, you only use like two rubber Orings on each shock, use the fatt ones if you have stock struts/shocks, you slide one down about 2 inches from the bottom so when you slide the threaded sleeve over it, it stays stable, then use one at the top, if you dont it will rattle all over and split the perch(bad)....make sure you trim the bump stops, and for gods sake dont put the top cover of the shock back on(the part that slides over the rod) or you will have to take it all back off, cause the car will sit on it,a nd wont lower down
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
owner/operator
