Crank Angle sensor OBDII B18C1
Old Jul 8, 2003 | 11:54 AM
Ralph's Avatar
TR Balla Donor Supreme
Default Crank Angle sensor OBDII B18C1
In order for a OBDII USDM motor to run in a OBDI using a OBDI ecu, do you have to use a OBDI distributor for it to run correctly. Reason being is that I was told that because of the location of the crank angle sensor on the OBDII B18C1 I'd have to swap out distributors for a OBDI GSR Distributor in order to read timing. Only reason I asked is because it appears to come from a good source, but when I've searched online through forums, faq's and so forth, I havent come across it in any of the articles that I would have to use a different distributor and in fact that if I had a USDM OBDII motor that it is totally compatible with the ignition componets. Being that said...and I ask because I dont know...is the crank angle sensor considered one of those componets, and if not, is that the point that I am totally missing.
TR Profile
Myspace Profile
Old Jul 8, 2003 | 04:52 PM
KJ's Avatar
KJ
bored at work
Yeah just rewire the plug and you are good to go. The sensor by the crank on obd2 cars is not a crank angle sensor. It is a crank fluctuation sensor (CKF). The ecu uses the CKF sesnor and cross references it to the distributor firing to detect missfires.
Old Jul 8, 2003 | 04:55 PM
Ralph's Avatar
Rewire what plug...could you be a little more specific. Thanks.
TR Profile
Myspace Profile
