few?
Old Jul 6, 2003 | 09:07 PM
StickyHydro318's Avatar
Default few?
I just bought a 89 crx si with a 92/95 patch si engine in it. sohc vtech
I got a few questions...
How come the check engine light is on?
with the ac not on it has a loupy idle..
Around how fast is it with i/h/e?
How come the temp gauge dont work when its warmed up?
When does vtech kick in?
when does the redline start?
is there anytihing i should look out for?
how much hp do these have stock? as in the engine thats in it right now.
i had an 89 crx dx auto, will there be any difference in the insurance rateS?
it has an act clutch in in and is pretty hard to press down, is that normal?
1996 Prelude
2004 GSXR 600
Old Jul 7, 2003 | 06:15 AM
Josh's Avatar
Dr. Doom
Default Re: few?
[b]Make sure your 02 sensors are hooked up right.[b/]
Idle air control valve, check air filter, TB, distributor, altenator.
Prolly at the most if you're lucky 120 to the wheels
Check your thermostat
it's 'vtec', and 5400 rpm
I would guess around 7k
129hp at the crank
shouldn't be
Yes, it has more clamping force than the stock clutch.
