4 piston calipers?
Old Jun 26, 2003 | 08:11 PM
Young,Fablous,&Broke's Avatar
I didnt know light cars needed them.
Old Jun 26, 2003 | 09:44 PM
StreetDriven's Avatar
I <3 your mom
I have seen a few typeR's that run nsx calipers. this is the only thing i could find but its for a 5 lug typeR and im not to sure if there is a difference? http://www.honda-tech.com/zerothread?id=531549
Old Jun 26, 2003 | 09:45 PM
I <3 your mom
and i have seen them go for around 500obo most of the time.
Old Jun 27, 2003 | 05:52 AM
RaIn.'s Avatar
Didn't know you could slow down from 60 to 130
Old Jun 29, 2003 | 10:31 AM
blurboEK's Avatar
proud father ;D
Go to Discount AutoParts (now Advanced AutoParts I believe) go to the back counter and tell them you need brake calipers for a 1995 Acura Legend GS. These are 2 pistons calipers (pistons are slightly larger than those found in the NSX calipers ) The calipers are around $52 with a $30-$40 core charge. Then pick up a set of bremo blanks (you will need to use a 5mm shim with the brake pads. Pick up some garbage brake pads for the calipers and grind them all the way down so there is no pad left and you will have your shim.) Might as well pick up some stainless brake lines, decent pads and high temp brake fuild.
-Mike
http://www.myspace.com/jdmmike02
2000 Ford Expedition Eddie Bauer
2004 Kawasaki ZX6R - SOLD
