question
Old Jun 16, 2003 | 08:06 PM
2nd_Gen's Avatar
Default question
has anyone ever done a obd 1 swap into an obd2 shell? i've got a 98 gsr shell and dropping in a 95 gsr swap. my question is what to do with the 2nd crank angle sensor in the block? is there any way to bypass that and if so, how would it or would it affect the performance? any help's appreciated, thanks.
Old Jun 17, 2003 | 07:05 AM
2nd_Gen's Avatar
yeah, the one near the oil pump. what am i suppose to do with that sensor?
Old Jun 18, 2003 | 08:33 AM
2nd_Gen's Avatar
can anyone help me out on this?
Old Jun 19, 2003 | 05:58 AM
KJ's Avatar
KJ
bored at work
Yeah you either need to swap in an obd2 oil pump and CKF sensor or run an obd2 to obd1 converter harness and ecu.
Old Jun 19, 2003 | 04:16 PM
2nd_Gen's Avatar
thanks KJ and kevin. i found out about the oil pump and sensor route yesterday and i think that's what i'm gonna do. do you guys know which route would be better and cheaper?
i have obd1 and obd2 ecu
have both ob1 and obd2 harness
and i can get a conversion piggyback from a friend
so with that info, which way do you think is cheaper? on a real tight budget right now. thanks again KJ and Kevin.
Old Jun 19, 2003 | 04:18 PM
2nd_Gen's Avatar
let me elaborate on that:
have both obd1 and obd2 harness (on the motor, still obd2 harness in the dash)
Old Jun 20, 2003 | 08:31 AM
2nd_Gen's Avatar
Kevin- so you're saying it's better to use the obd2 harness on the motor+use the obd2 harness that's in the dash+run a obd2 to obd1 conversion harness to a obd1 ecu? i just wanted to make sure, thanks for your help.
