stutter...
Old Jun 12, 2003 | 09:34 PM
Hybrid Crx Si's Avatar
Holding Monster
Default stutter...
my motor (B16A) stutters/hesitates when i give it gas sometimes... not all the time and not at any certain rpm... sometimes it doesnt do it at all, but im guaranteed to be plagued with it every time i drive (it happens pretty often)... the weird thing about it is that it never happens when the car is cold, only after the motor warms up to the normal temperature... the computer isnt throwing a code and everything is normal except for this...
anybody have any idea what this could be? i have changed plugs, plug wires, distributor cap, rotor, rewired the knock sensor, checked spark, etc, i even ran a compression check... everything was fine... im completely stumped...
"wear your lifestyle"
www.venndk8.com
www.facebook.com/venndk8
Old Jun 12, 2003 | 10:06 PM
RaIn.'s Avatar
Mine was doing the same thing, and it was a loose wire in my conversion harness. So check for some bad wiring somewhere...
Old Jun 12, 2003 | 10:13 PM
Holding Monster
thats one thing i didnt check, ill have to do that... thanks bro...
www.venndk8.com
Old Jun 12, 2003 | 11:04 PM
StreetDriven's Avatar
I <3 your mom
How bad is it?
Old Jun 13, 2003 | 06:56 AM
ComatoseSedan's Avatar
Fo Shizzle My Nizzle
if your motor is a JDM motor, which I'm sure it is.. this problem is caused by the fact that the motor is designed to run off 100 octane fuel ( because they have that in Japan ). what grade fuel do you use? even with 93 you'll get this surging every now and then. the solution is to install a fuel press. reg and just raise the fuel pressure about 2-3 pounds and it should run better. this is one theory, the problem could allways be something else but this is one of the common ones.
'88 Civic Sedan - Cardinal Metalic Red
153.5 whp AllMotor
www.LHTperformance.net
Old Jun 13, 2003 | 07:27 AM
Holding Monster
i never run anything less than 93 octane... anything less would be uncivilized...
sweet... thanks man, ill try this too...
www.venndk8.com
Old Jun 13, 2003 | 07:30 AM
Holding Monster
Originally posted by StreetDriven
How bad is it?
you havent heard it?? you can hear it in my exhaust...
www.venndk8.com
Old Jun 13, 2003 | 09:58 AM
KJ's Avatar
KJ
bored at work
This will sound stupid but give it a try if nothing else works. Switch the o2 sensors if it is a b16a1 motor with two sensors. I've done this several times on a1 motors that are stuttering and it fixed it every time.
Old Jun 13, 2003 | 11:23 AM
Wow ! mine was'nt that bad, still sounds like a fuel problem to me.
153.5 whp AllMotor
