88-89 teg motor will wire to 90 hatch?
86-87 teg motors will go into 1st gen crx's right?
and 88-89 will go into 88-91 crx/civic.
change the front mount or someshit and the wiring should all be he same right??
any help is appreciated
or can i use 86-87 teg and use 88-91 harness?
whats the easiest way out
88-89 WILL NOT BOLT UP IN A CIVIC /CRX BUT WILL WIRE UP
86-87 WILL BOLT & PLUG UP IN A 85-87 SI CRX
IF ITS A DX OR HF IT WILL NOT WIRE UP UNLESS U REWIRE & RUN A FUEL PUMP/LINE.........
been there done that 86 dohc si......
u GUYS can SUCK my BALLS
