tranny chart/gear ratio chart
Old May 24, 2003 | 07:39 PM
styles999's Avatar
Powered ByYo Mommas Mouth
Default tranny chart/gear ratio chart
found a chart for all you ppl that want to
find out if the tranny will fit in your car
http://www.dragracingpinoy.com/artic...trans_001.html
and some gear ratios along with it
http://www.teirney.net/civic/GearboxRatioReference.htm
and some interesting fact that i didnt know about
taken from http://www.jdmhondaparts.com/engine_faq.htm
"PS is a measurement of horsepower on a European and Japanese platform. PS is actually a French (metric) horse power, defined as 1 PS = 735.5 W (watt). On the other hand, British horse power (HP) is about 746 W. (1PS = 0.9859HP).
Original definition was: 1PS = 75 kgw*m/s, 1HP = 550 lbw*ft/s.
When comparing PS to HP, PS is usually rated a little higher than HP -- about 3-5hp more. So, for example, a JDM hydro B16A engine is rated at 170ps, when converted to HP, it's around
165-168hp; and that's usually the estimated power to the wheels too."
