obd0 b16a1 into a 90 ls question
Whats up.
Ok ive done a few swaps already, but this one may be a tricky one. This guy already bought his swap and its a jdm b16a1. I believe the wire harness that comes with the swap will not work in the car its going into. (90 Integra LS). Now I know it bolts up. Can I use the wire harness that is already on the LS motor and then just go ahead and add another wire for the vtec or will it just be easier to try and find an obd0 wire harness? Also any other issues i should know about with this one? I appreciate all the help. Just want to make sure this works out for us.
Chris
Chris
03' BMW 330XI
03' BMW 330XI
Use the stock 90 teg harness and there will be five wires you will need to run. The b16a harness will not work since it is for a RHD car. The b16a harness is only good for plugs.
Gracie Barra Clearwater
