over bore?
Old May 12, 2003 | 10:34 AM
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
Default over bore?
does a .25 over bore make a big difference? how much of a difference would a ls motor with oversized type r pistons make. about how much hp would that add?
tamparacing.com
Old May 12, 2003 | 11:10 AM
Josh's Avatar
Dr. Doom
Originally posted by `92CXhatch
the overbore itself is normally done just to ensure that the cylinder wall is perfect... it will help with power but not enough to take apart a good block just to use over sized pistons...
-Keith
werd
Old May 12, 2003 | 11:13 AM
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
can some one tell me how much is not enough power? im looking to see if its gonna add some good numbers my adding .25 oversized type r pistons in a ls motor
tamparacing.com
Old May 12, 2003 | 12:29 PM
Josh's Avatar
Dr. Doom
Originally posted by Cronic
the oversized ITR pistons would raise your compression. I can't remember how much tho. The overbore itself would add very little. Almost unnoticable.
Ok, did you read what cronic said?
Old May 12, 2003 | 12:45 PM
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
ok did you notice the time he posted and the time i posted? 1 minute apart. i was typing while he was typing
tamparacing.com
Old May 12, 2003 | 01:17 PM
KJ's Avatar
KJ
bored at work
It just assures that the cylinder wall is true round. Also when overboring the builder can tell the machine shop the piston to wall clearance he or she desires. I try to always use overbore pistons in the motors I build. The machine work costs a little more but I feel it is worth every penny. Talk to anyone of the guys on this board who have had motors built with too much piston to wall clearance by honing and running standard bore. It is definitely a good thing to do.
Old Mar 1, 2011 | 03:01 PM
shanefoster's Avatar
The overbore itself is commonly done just to ensure that the cylinder wall is perfect. It will advice with ability but not enough to yield part a good block just to use over sized pistons.
